Changing MAP lamps!
the entire center console plastic piece is snapped to the roof. Just pull down on it : start from the emd with the home linik and work your way around to the windshield.
don't know if this will help, i don't know if anything is the same on my car but its worth a shot
https://www.audiworld.com/forums/sho....php?t=2811768
I posted a writeup a while back about how to replace the interior bulbs in a Q7 with LED ones. I covered the map light in there. See:
https://www.audiworld.com/forums/sho....php?t=2786686
BTW, I remember the map lights being tricky to get out because you need to spin them and pull them out at the same time. I eventually got them out, but one of mine fell between the seat and the console and disappeared deep under the floor. Luckily it doesn't rattler. I HIGHLY RECOMMEND COVERING THIS AREA WITH A TOWEL BEFORE YOU TRY TO PULL THEM OUT.
(I totally forgot about the visor lights -- they're still regular bulbs).
Hope this helps.
Hope this helps.
ICMK
Q5/SQ5 MKI (8R) Discussion
03-16-2017 03:12 PM
TTlegend
01-02-2006 02:19 PM
LouisR
04-13-2002 06:50 AM
