2010 Q7 A/C
Am I missing something, or does the air not blow too cool in this vehicle?
Even when on "Lo" and auto with maximum fan, the air does not get cool enough -- any ideas? |
i thought the same thing too in my 2007. It does cool down--wonder if it has more air volume to cool down than, say, a 4 series.
What color is the interior? Are you noticing this when you turn the temp to LO, or is still not "cold" after x minutes? How warm is it it outside, and inside (approximately)? |
make sure A/C button is lit, i had mine in auto and it was hot inside my 2010 q7, but for some reason the a/c button wasn't lit, i had to manually hit the ac button to get cool air even in auto setting, haven't been able to play around with settings, so i can't really elaborate any further, but this happened to me the first time it got hot inside my q7
Originally Posted by IAS5
(Post 23959778)
dumb question- but are your vents open? Each has a dial next to each vent to open or close them.
Apologies for appearing to insinuate you might not have known this.... |
Mine cools fine thusfar, but haven't experienced the Texas heat yet with this vehicle. Find out in a couple of months.
(Post 23959934)
My 2010 Q7 Also had this problem(A/C not cold) and I just got my car only 2 weeks.
So I went to the dealer to check this morning and found my car's refrigerant was leaking from the pressure switch. They replaced a new one for me and refill the refrigerant. Now my car is back to normal again and I will continue to watch if it will happen again. I also heard form the dealer this was fifth or sixth same case in our country. |
Interesting -- may have to look into this -- thanks!
