2012 Q7 3.0T Starts and then dies
See the video at
Anyone ran into this before? |
I saw that behavior in my 2011 - i know this sounds stupid, but is the fuel below 1/4 of a tank?
Seems like whatever you did, it fixed it, but more details about what "part" you installed would help. |
Thanks for the feedback arU4ic. The part I replaced was the temperature and pressure sensor: . It didn't solve the problem. I'll pay attention to the gasoline fill level to see if it is only when below 1/4 of a tank.
Originally Posted by Monte Wingle
(Post 25035871)
Thanks for the feedback arU4ic. The part I replaced was the temperature and pressure sensor: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 . It didn't solve the problem. I'll pay attention to the gasoline fill level to see if it is only when below 1/4 of a tank.
Thanks for the help and advice. I ended up taking it to the dealer because the problem continued to worsen. It turned out to be the high pressure fuel pump. Cost to replace was $700, and well worth it, it is running great now.
(Post 25121376)
(Post 25121376)
(Post 25121376)
Going to bump this thread instead of starting a new thread. My 2013 is doing the exact same thing, It will die each time i try to start unless I give it a lot of gas, then it cranks up and runs. Anyone else ran into this problem and resolved it with replacing the pump?
I had this same issue with our old 2007 Q7 with the 4.2 V8. The left side HPFP failed both mechanically and electrically, resulting in a ton of fault codes, I chased my tail for days. The engine would start, but idled very rough, had no power, etc.
