Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Ad Blue problem
Old Mar 2, 2010 | 07:33 AM
supergreen's Avatar
Default Ad Blue problem
HAs anyone had the Ad Blue message come up? I have a 2010 with 1700 miles on it. I had the ad Blue message say need to fill in 1500 miles. this is way early so I had my dealer investigate and the tank was way low so they added several gallons. Well, now less that a month later I'm getting the same message. The dealer says they checked the pump and it was fine. If I have to get the tank filled again I can only assume I have a leak.
Anyone else had any ad Blue issues?
Old Mar 2, 2010 | 07:41 AM
supergreen's Avatar
Also, Does anyone know if the ad blue stinks? I would imagine it smells like urine but I don't know. I haven't seen any puddles or anything.
Old Mar 2, 2010 | 12:09 PM
Edge's Avatar
Audiworld Senior Member
~3500 miles on mine, no Adblue messages on mine yet. Sorry can't help.
Old Mar 2, 2010 | 12:25 PM
capnmwf's Avatar
i've got a 2009, adblue was filled at 15,000 mi. service, no issues.
Old Mar 2, 2010 | 02:02 PM
Railflyer's Avatar
your dealer failed on the PDI to properly reset the adblue warning. They went through this when they first came out in 2009. You would think they would read the factory messages telling them what to do. Personally it is inexcusable now.
And yes this happened to me right after the first service. Problem is I had a nearly full tank but for some reason that does not matter. Your tank can be full but if not reset properly it still wont start in 1500 miles.
Old Mar 2, 2010 | 06:08 PM
Jusforfun's Avatar
Current discussion in the TDI Discussion forum.
https://www.audiworld.com/forums/sho...php?p=23933486
I also read that the rate of injection can be adjusted but must be within certain parameters so perhaps your dealer could check it.
See also thread re TSB about 4 down in TDI forum
Old Mar 2, 2010 | 06:12 PM
supergreen's Avatar
Thanks, I have a service appt on friday. I will let you know what was the result then.
Old Mar 4, 2010 | 02:49 PM
oaktreelimb's Avatar
Your dealer tech failed to follow proper procedure for refilling Adblue in your car. Each time 1.5 gallons (6 liters) or more of AdBlue is added to the system (during PDI or other service procedure), an adaptation must be performed using scan tool. When you are at your dealer, ask them about this adaptation procedure and check TSB 2021834/1.
Old Mar 5, 2010 | 07:25 AM
supergreen's Avatar
I called my tech who has my Q now (and threatened to keep over the weekend). He said he would look up the TSB. Thanks so much for the specific knowledge.
Old Mar 5, 2010 | 04:42 PM
supergreen's Avatar
I Got My Q back from the shop today. They decided the fuel gauge for the ad blue tank is bad. Now a new one must be ordered from Germany. It will take 10-14 days. I hope I don't need to go more than 1500 miles by then.
I worry about how much of the car must be taken apart to get to the ad blue tank. I know it is located above the wheel well by the fuel door.
HBarlow
TDI Discussion
May 12, 2017 03:24 PM
Global Autosports
Other (Non-Audi) Autos Discussion
Sep 6, 2012 10:45 PM
ITALSKIER
9
Jan 5, 2007 04:44 AM
a4mulet30red
Oct 8, 2002 07:52 PM
