Cannot enter modules
I have 2 modules that I cannot enter/read.
05 Acc/Start Auth - it just circles until I kill the program
25 Imobilizer - I get a pop up [failure to communicate (-1) Please use [options]> [test] for further details. After doing this I get No Response from Controller.
I cleared all DTCs to see if that would help.
Any Ideas? Where would one begin? Where are either of the modules located and can they be tested?
Thanks in advance.
There are modules you cannot change anything till you enter the security code, but it should let you into the module.
I unlocked the video security to enable VIM video in motion. The security code reflected below was from an MMI update.
I am very handy with the program now, in fact, just learned something new about it.
Changed out a read txt. to enable running with deleted modules. Rather fascinating.
Here is the scan I just ran with said delete!
Tuesday,21,March,2023,15:58:21:45450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 23.3.0.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: WA1DGAFE6FD008394 License Plate:
Mileage: 239950km-149098mi Repair Order:
Chassis Type: FE-AU56 (Fe - MyAutoScan)
Scan: 01 02 03 08 09 10 15 16 17 19 28 34 36 3C 42 46 47 4C 4F 52
55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE6FD008394 Mileage: 239950km-149098miles
Address 01: Engine (CTW) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0928
Shop #: WSC 31414 790 00001
VCID: 3635DBE4644C651AE5F-8062
VINID: 9D10545D15951965000080C910D2ABCAB2
1 Fault Found:
001110 - EVAP System
P0456 - 000 - Very Small Leak Detected - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 239484 km
Time Indication: 0
Date: 2023.03.05
Time: 11:58:25
Freeze Frame:
Lambda: -7.5 %
Temperature: 18.0°C
Time: 2.20 s
Time: 4.20 s
Time: 76.8 s
Temperature: 16.5°C
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Serial number: CVN: 354289C1
Coding: 00B178
Shop #: WSC 30586 001 104857
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 3A2DCFD45CD4817A017-806E
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0103505
VCID: 3431E1EC7230770ADBB-8060
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000000447079
Coding: 001CC026
VCID: 25170CA8C5EA1E825C5-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0115208822
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0115208818
Coding: 070000
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0133123
VCID: 6E8533845C9C1DDAEDF-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961425401612
Coding: 29011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3431E1EC7EB0770ADBB-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH45 0230
Revision: 09H45000 Serial number: 0038QD90ASU+
Coding: 0014131
VCID: 2B03FA90AF0E28F28A1-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME79421A4EQ
Subsystem 3 - Serial number: 6342QSME1F431D4CT
Subsystem 4 - Serial number: 6352QSME43445458E
Subsystem 5 - Serial number: 6362QSME3D44327ES
Subsystem 6 - Serial number: 63734SME71424B54$
Subsystem 7 - Serial number: 63834SME0D454E605
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026142050193
Coding: 0012142
VCID: 2809059CBEF803EA673-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 S HW: 4L0 920 985 S
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2R52NJ9F
Coding: 8BDE63040901CF05020205
VCID: 44D1B12C2E90C78A6BB-8010
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M1490204F4
Coding: 00C303
VCID: 3FDBBEC04776A452369-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 41250510334121764484
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 239952 km
Time Indication: 0
Date: 2023.03.21
Time: 13:39:00
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000030351854
Coding: 0000006
VCID: 6889459C7E78C3EAA73-803C
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
Shop #: WSC 29409 001 1048576
VCID: 313FE8F88D224222B0D-8064
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000114006321
Coding: 00581B00000011110000
VCID: 323DE7F48424793AC97-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E05F3849C1C5DDAADF-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H03 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F28.08.1400H03000AMS14277ÿ
Subsystem 4 - Serial number: S14277ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000118410359
Coding: 011F57205E40440004
VCID: 48C9A51C12B8E3EA873-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82007937900000
Coding: 3570077
VCID: 3829D5DC6E58936AF73-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000060077
Coding: 030000
VCID: 290F0098A9F23AE278D-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191069910
Coding: 0694221
VCID: 231312B0C7DEE0B2321-8076
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000196405
Coding: 0002001
VCID: 5EE56344AC3C8D5A5DF-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000118095476
VCID: 47CBA6201FA6EC928E9-8012
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 239952 km
Time Indication: 0
Date: 2023.03.21
Time: 11:34:29
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000032
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H60 0138
Revision: AB001007 Serial number: 156I.0E8063162
Coding: 020007010000000000
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4L2 035 746 H HW: 4L2 035 746 D
Component: H-BNT-NA H41 1040
Revision: -------- Serial number: 224IU0E7551041
Coding: 180200060304F1FF57003F4D6D632003140000000100000000
VCID: 3333E2F07B3E7032C21-8066
Subsystem 1 - Part No: 8R0 060 884 EN
Component: NAR 2017/2018 1602
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130IY0E3128854
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002205827
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
1 Fault Found:
03623 - Invalid Security/Release Code
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 183
Mileage: 239952 km
Time Indication: 0
Date: 2023.03.21
Time: 11:34:31
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000117954997
Coding: 010E57204040230004
VCID: 46D5AB2418ACF59A75F-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00008200812238
Coding: 0200000000000000
VCID: 313FE8F881224222B0D-8064
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0171124
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E853384501C1DDAEDF-803A
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81398C6A80EFCAC3B-8038
Subsystem 1 - Part No: 4L0 910 946
3ó
Subsystem 3 - Serial number: RD12.09.14--H58001002G0094ÿ
Subsystem 4 - Serial number: 2G0094ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0118255819----
Coding: 0003587
VCID: 26150BA4B4EC159A55F-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H15 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H15 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H15 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000117954996
End----(Elapsed Time: 02:12, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 239484 km
Time Indication: 0
Date: 2023.03.05
Time: 11:58:25
Freeze Frame:
Lambda: -7.5 %
Temperature: 18.0°C
Time: 2.20 s
Time: 4.20 s
Time: 76.8 s
Temperature: 16.5°C
Coding: 00B178
Revision: 00H02001
Coding: 0103505
Coding: 001CC026
Coding: 070000
Coding: 070000
Coding: 0133123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 29011F
Coding: 0014131
Coding: 0012142
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 239952 km
Time Indication: 0
Date: 2023.03.21
Time: 13:39:00
Coding: 0000006
Coding: 0015520
Coding: 0010001
Coding: 3570077
Coding: 030000
Coding: 0694221
Coding: 0002001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 239952 km
Time Indication: 0
Date: 2023.03.21
Time: 11:34:29
Coding: 0000032
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 183
Mileage: 239952 km
Time Indication: 0
Date: 2023.03.21
Time: 11:34:31
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
3ó
Coding: 0003587
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 239484 km
Time Indication: 0
Date: 2023.03.05
Time: 11:58:25
Freeze Frame:
Lambda: -7.5 %
Temperature: 18.0°C
Time: 2.20 s
Time: 4.20 s
Time: 76.8 s
Temperature: 16.5°C
Coding: 00B178
Revision: 00H02001
Coding: 0103505
Coding: 001CC026
Coding: 070000
Coding: 070000
Coding: 0133123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 29011F
Coding: 0014131
Coding: 0012142
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 239952 km
Time Indication: 0
Date: 2023.03.21
Time: 13:39:00
Coding: 0000006
Coding: 0015520
Coding: 0010001
Coding: 3570077
Coding: 030000
Coding: 0694221
Coding: 0002001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 239952 km
Time Indication: 0
Date: 2023.03.21
Time: 11:34:29
Coding: 0000032
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 183
Mileage: 239952 km
Time Indication: 0
Date: 2023.03.21
Time: 11:34:31
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
3ó
Coding: 0003587
