help 07 Q7 4.2 EPC and other lights on
Recently my car threw up a EPC, traction control and CEL. Can hardly run and sputters. I pulled the following codes and was wondering if anyone knew where I should start? What would be the main problem as some codes get thrown since its running so bad.
P0087 Fuel rail system pressure low P0102 Mass or volume flow circuit low input P129B Fuel Pressure regulator valve N276 Bank 2 open Circuit P2231 O2 sensor signal circuit shorted to heater circuit Bank 1 sensor 1 P2401 P2294 P0087 P0458 P2257 P010C |
I got the EPC light on mine about six months ago. My research led me to replacing the high pressure fuel pressure sensor that is found on the fuel rail at the rear of the engine underneath the decorative cover. Replaced it and haven't had any issues since. (knock on wood). It was a fairly easy install.
My codes were: 000136 - Fuel Rail/System Pressure P0088 - 001 - Too High - Intermittent 008584 - Bank 1; System too Rich at Idle P2188 - 008 - - Intermittent 008592 - Bank 2; System too Rich at Idle P2190 - 008 - - Intermittent |
My hunch is either the battery or ECU. Those codes don't point to a common problem (fuel pressure, voltage issues, airflow). If your battery is more than a few years old, I'd put my money on that as the culprit. The Q7's engine management electronics are very sensitive to voltage fluctuations and often show up as symptoms of a dying battery.
The battery was done in October at the dealer so not even a year old. Hmm
Originally Posted by Audi400
(Post 24844798)
So you guys think battery? Should I put it on a trickle charger and see if it helps to be at full charge?
It starts fine and like I said battery about a year old. Hmm |
(Post 24848024)
Would you guys think my codes point to a fuel issue? Had battery checked and its fine. I see some fuel codes.
(Post 24848967)
Originally Posted by Tsg8397
(Post 24849156)
Oh! Fuel pump!
