Just ordered a VAGCOM
any codes out there to turn off chimes and such like you can do in the Touareg?
I'm hoping for the same info. I'm hoping I can connect with my VAG-COM and do a little
customizing when our Q7 arrives ;-)
Windows Up/Down with remote
Module 46
Enable Comfort: Add 128 to existing coding Adaptation (10) Channel 61: Add 5 to existing coding. ========== <a href="http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Comfort_System">http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Comfort_System </a> 0000001 = Reserved (always) 0000002 = 10 Tamper Alarms (PR-B09) 0000004 = Thatcham inactive (PR-7AA/A8U) 0000008 = Selective Central Locking (PR-4K2/4K7/4K8) 0000016 = Anti-Theft Warning System (PR-7AN/7AL) 0000032 = Inclination Sensor installed (PR-7AN/7AL) 0000064 = Interior Monitoring (PR-7AL) 0000128 = Comfort Function via Remote (NOT PR-B29/B30/B34/B35) 0002048 = Confirmation Anti-Theft System via Horn (PR-A8U) 0004096 = SAE Rear Lights (PR-A8U) 0008192 = Light Package (PR-QQ1) 0016384 = SAFE-Function deactivated (PR-A8U) 0065536 = No Anti-Theft Delay (0 Seconds) 0262144 = Sunroof / Open Sky System (PR-3FU) 1048576 = Luggage Compartment Closing Assistance (PR-4E7/4E9) 2097152 = Rear Lid Control Module (PR-4E7/4E9) 4194304 = Fuel Lid Unlock via Driver Door Button Note: Coding is the sum of the individual options. Not all options apply for all control moduls! ======= Adaptation Channel 061: Changed to: 15 (+1 and +4 = windows closing via Remote Control) Channel 061: Comfort Functions +001 = Comfort Closing: Window Regulators via Remote Control +002 = Comfort Opening: Window Regulators via Remote Control +004 = Comfort Closing: Sunroof via Remote Control +008 = Comfort Opening: Sunroof via Remote Control +016 = Comfort Closing: Window Regulator via Switch Drivers Door +032 = Comfort Opening: Window Regulator via Switch Drivers Door +064 = Comfort Closing: Sunroof via Switch Drivers Door +128 = Comfort Opening: Sunroof via Switch Drivers Door +256 = Comfort Closing: Window Regulators via Lock Cylinder +512 = Comfort Closing: Sunroof via Lock Cylinder Note: Adaptation value is the sum of the individual options. |
Seatbelt Chime disable
Module 17 (Instrument Cluster)
Default Coding: 2641263 New Coding: 2641203 NOTE: Your coding may be different than mine. I used the following coding guidelines to change the next to last digit from "6" to "0" <a href="http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Instrument_Cluster">http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Instrument_Cluster</a> ????xxx: Options +0001 = Quattro (Standard) +0002 = w/o Driver Information System (DIS) +0004 = Vehicle with Clutch (NO Automatic) +0008 = Second Tire Size Pair +0016 = Tire Pressure Monitoring +0032 = Adaptive Air Suspension +0064 = Advanced Frontlighting System (AFS) +0128 = Adaptive Cruse Control (ACC) +0512 = Vehicle w/o Electronic Parking Brake (Standard) +2048 = Switch Option for Bord Computer Levels xxxx?xx: Country 0 = Germany 1 = Rest of World (Left-Hand-Drive) 2 = USA 3 = Canada 4 = Great Britain 5 = Japan (Left-Hand-Drive) 6 = Arabian States 7 = Australia 8 = Rest of World (Right-Hand-Drive) 9 = Japan (Right-Hand-Drive) xxxxx?x: Seatbelt Warning 0 = No Seatbelt Warning 1 = Seatbelt Warning (EU-NCAP) 2 = Seatbelt Warning (NAR Old) 3 = Seatbelt Warning (NAR New) 4 = Seatbelt Warning (EU-NCAP incl. Passenger) 5 = Seatbelt warning (NAR Old incl. Passenger) 6 = Seatbelt Warning (NAR New incl. Passenger) xxxxxx?: Illumination 0 = Needles OFF and Scales OFF (Term. 15 ON / Term. 58 OFF) 1 = Needles ON and Scales OFF (Term. 15 ON / Term. 58 OFF) 2 = Needles OFF and Scales ON (Term. 15 ON / Term. 58 OFF) 3 = Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF) |
I'm curious about channel 050 (adapative brake lights)
I wonder if it can be enabled on US models.<ul><li><a href="http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Comfort_System">http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Comfort_System</a></li></ul>
thanks, that's what I need
MarkItZero
Where did you buy your VAGCOM?
How much are they going for? |
Ross Tech..
$349. You need a laptop computer to use with it.<ul><li><a href="http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=VCHUC&am p;Category_Code=VAGCOM">VAG-COM License with HEX-USB+CAN Interface</a></li></ul>
Ordered mine just now
Hmm. Interesting. But what does it do, exactly? Can't find any Audi specific info on Google or AW
