Sirius Radio - Linking?
I finally signed up for Sirius radio through my '07 Q7. When listening, I get silence with "Linking" displayed on the screen. This happens quite a bit. Is this something that I can correct?
Suggestions? Thanks |
This happens to me quite often on my Q5. I wonder if it is a problem with the radios themselves.
...Jose |
Is there an antenna that could be damaged?
maybe.
I would check: - power harness of the sirus radio box - antenna harness and connector, fits tight, nothing lose or broken - antenna cable, broken somewhere, kinks, sharp bends - all other cables thru the antenna If this is all ok, the antenna could be broken, or the sirus radio box. |
Originally Posted by jestertc
(Post 24225506)
maybe.
I would check: - power harness of the sirus radio box - antenna harness and connector, fits tight, nothing lose or broken - antenna cable, broken somewhere, kinks, sharp bends - all other cables thru the antenna If this is all ok, the antenna could be broken, or the sirus radio box. Thanks |
Originally Posted by eldoj
(Post 24222069)
Ours does this infrequently as well. Most of the time it happens while going under highway underpasses and there are certain areas of road in which it repeatedly occurs. I guess there are dead zones just like with cell phones. If yours is doing this all the time there is likely a problem with your car.
Originally Posted by chickdr
(Post 24226654)
HEY J,
open the rear lid and on the passage side there is a compartment where the control for the xm unit,we have had Q7 sunroof drains leak water onto the control units,ck to see if u have water damage,should be white strains ther if so,hope that helps, DAN B. OR U COULD VAG IT FOR FAULTS, |
Originally Posted by audi01a6
(Post 24226965)
HEY J,
