TPMS MALFUNCTION
getting tpms malfunction NOT low pressure warning. Do i have to buy sensors
1.from where 2.cost 3.can any tire shop do it (need vag or not) 4. Have to replace 1 or all ( how do i know) |
Need to know what year your Q7 is.
i just got the same problem about 4 days ago while driving. i have a 07 q7 s-line.
It is Audi 2008 Q7 3.6 premium
This is by no means the only possible issue, but assuming you are both still running your stock wheels, you could be looking at dead and/or dying batteries in the sensors that are mounted in your wheels. Tire rack and others sell replacements. but you'll have to have a tire shop remove your tires from the wheels to swap the sensors out, then remount and balance the tires. Maybe Audi would help... I'm not sure how they would treat the failure of a safety item out of warranty. It certainly wouldn't hurt to ask.
is it true if you buy replacements its not as simple as removing tires and installing new ones. but they have to be programmed too?
I believe your MMI should have a menu option to signal that you've change wheels. If I recall correctly, it is right next to where you tell it to re-learn the tire pressures. Normally, that's all you would need to do.
Me it was the antenna 2007 Q7 premium 4.2
Recenlty I got an issue with TPMS my local garage use a tester near the wheels and told me sensors are all good. VCDS something related to the antenna. Got a used antenna on ebay for 40$, same part as A6... Just replaced and works fine. The antenna is on right side under the car and under the long black trim you need to remove.
Originally Posted by va-terps4
(Post 24563852)
Originally Posted by audiblack73
(Post 24563605)
1.from where 2.cost 3.can any tire shop do it (need vag or not) 4. Have to replace 1 or all ( how do i know) I am getting a TPMS malfunction message. I am new to Audi and purchased a 2012 Q7 TDI prestige last week. The dealer I purchased from does not work with Audi and would not look at the issue. No big deal as it seems to be the only issue this vehicle has and it was a great deal. I seem to be getting two different lines of information now. I assumed the batteries were dying in the sensors, as I have had this issue in the past on other vehicles. When I look up parts information from Audi vendors they list TPMS sensors for the wheels. But when I just took the vehicle to a local tire store. They went to read the sensors to see if the batteries where dead and all of their equipment is telling them that the Q7 uses indirect TPMS. The tech and I worked through the directions to reset the system in the MMI and I have driven it since. The system has never reset and I am still getting the message. I am left with two questions: 1. are there sensors in the tires of this model. 2. What would be the next step for a DIY fix, or should I break down and take it into an Audi dealer? thank you |
