Wheel alignment at tire shop vs dealership?
Ok, so I read a couple of posts where people were asking if they can take their car (in my case a 2011 Q7) for wheel alignment to a tire shop, instead of the stealership.
Most of the people say go to the stealership, but they don't explain why? Isn't wheel alignment a usual process based on some standard devices and numbers? Why would only the stealership do a great job at it? In my case they have long waiting periods, it's 40%-60% more expensive and it's 30 minutes away compared to the 3 minute drive to Town Fair Tire in my neighborhood. Looking forward to your point of views and reasons why! Thanks. |
Originally Posted by drcyrus3d
(Post 24311397)
Stealership informed me that the Q7 suspension setting for alignment is unique and requires a computer setting (assuming pneumatic suspension). The only shops that should do alignment are the Audi certified shops.
I know in one city near me where the Audi stealership contracts out alignement to a specialist shop with the needed equipment and training. Of course, Stealerships have been know to be "economical with the truth". :-/ |
Took my '10 TDI to the local tire shop for the wheel alignment. Works fine for me.
I see at Audi dealership they have like an Audi-branded alignment setup. Got all the Audi logos on it, so I'm not sure who the OE vendor is on the equipment. Maybe it is Audi-specific, I'm not sure. But the tire shop route works fine for me. I don't have the air-suspension thought. -ThinkMac- |
So I took the Q7 to a tireshop for alignment and then I took it to the stealership. The stealership gave me a printout from the computer that my alignments were off. So the tire shop din't do it based on audi standards.
I don't know what to think anymore ... |
Unless your Audi has Lane change departure and/or adaptive cruise control system, you don't need Audi dealer to do alignment. Q7 alignment is a little bit tricky. Alignment of Q7 front Caster, Camber angles job is not for rookie tech.
(Post 24323452)
Your local dealer probably outsources anything relating to alignment/tires to the local tire 'specialist' anyways. Although, from experience at my local 'specialist', a special tool is needed to adjust the Q7 in someway (I dont remember details).
Since then, I would recommend 'performance' specialists for tires and if need be, alignment. Having said that, I've run well over 100,000km and only changed/rotated tires with no alignment since delivery. The only issue i get with tires relates to the rear set, wearing more on the 'inside' of each tire. I put this down to the fact that I have adapative suspension and I spend a long time at 'highway' speeds, so the rear end is sitting rather low (similar to 'loading' position). In short, change/rotate tires and alignment if its critical! |
