20 Inch wheels to 19 or 18s
#11
I have the same setup. Like it. I did replace MSW center-cups with black Audi rings center-cups form amazon.com and wheels looks even better with them.
#12
Yeah, I did that with some Alzor reps I put on my A4. One of the things I dislike about my Mandrus setup is that the center caps are much larger (70mm-ish, I’m guessing). The center bore size is perfect at 66.56mm, but the caps are a strange size for which I can’t buy Audi knock offs. :-(
#13
Thanks for sharing, if I buy a set of four tires and wheels and have Tirerack mounted them and ship to me, do I need to worry about TPMS if I put them on myself? Or I would need to bring the car to the shop to have them installed?
#14
There are no TPMS sensors. You just have to reset the TPMS through the MMI once you fit the new wheels/tires.
#17
Bolts, hubcaps, quality
Yes. I just put 19s on mine for the winter. Mostly I was trying to find a cheaper solution for snow tires than the absurdly expensive 20” tires that fit the stock wheels. But I’m quite happy with the results with respect to ride quality. The car is a bit “splashy” in the corners now, though...
Here are a couple pics.
Mandrus “23” wheels in matte black. 19” by 8.5” wide, ET25.
#18
No, you can’t re-use the Audi bolts. The Audi wheels use hemispherical seat bolts, but most aftermarket wheels (Mandrus included) use conical seat bolts. The length is different, too (though I don’t remember what size is required for the Mandrus wheels). Discount Tire includes bolts with the wheels. The same should be true of most retailers.
The center cap / hub cap is about 70mm diameter. That’s the OEM size for Mercedes Benz. Mandrus wheels are popular in the MB aftermarket, but the bolt pattern and center bore size matches Audi, too. I have not been able to find a knock-off center cap with an Audi logo in that size. The best I can find is blank center caps and a 70mm sticker. I think a sticker would look pretty crappy up close, and the Mandrus caps look good enough for me. I gave up looking for Audi style caps months ago...
My personal experience with matching bolts and wheels was a nightmare. First, Discount Tire didn’t ship the bolts with my wheels. Then, they sent bolts that were too long and drove into wheel bearing hub on the back wheels. I was in a rush to get the winter tires on the day before a road trip, and I didn’t have time to shop around for more bolts or return them to get the right size. Instead, I got my shop to cut them about 1/4” shorter with an angle grinder. That worked fine for me, though in the long run I’m worried about the thread getting boogered up. Long story short - make sure you lean hard on the seller to include bolts of the appropriate length. Apparently, Discount Tire has the wrong size in their database for the 4M Q7.
#19
Oh, also, the fit is great. I’ve been running these wheels for about two months, and they are great. The ride with the winter tires is soft and supple. There is no rubbing even at full lock. And with the very low offset, the wheels are pushed out to about the same depth (nearly flush) as the OEM 20” wheels. I have to say, though, that after a couple months of seeing them daily, the black on black without a complete BOP looks a bit weird. I can’t decide if I like it or not...
#20
Thanks for the reply. Too bad the lug bolts don’t fit, otherwise it’s a great looking brand Mandrus by TSW. I’ve found these Audi hubcaps that are bigger and might fit. For $15 I’d give it a try even if you have to file it down a bit. https://www.ebay.com/itm/4x-77mm-Bla...=1901497506001
foxmoor
Q7 MKII Discussion
07-04-2018 09:30 AM
Small Town Terrorist
Audi allroad
07-22-2005 12:47 PM
Struggling with 18" or 19" wheels? My TTqR is a summer car and I would like to know your thoughts..?
The Mystro S4
17
07-07-2003 09:50 AM
kkouddous
29
11-20-2002 07:54 PM
