2017 Q7 BRAKE ISSUES, NO FIX IN SIGHT
#21
I am at 22k and mine squeal like nobody's business for the fist few feet and then all is normal. It drives my wife nuts as I get just the right speed for it to be loudest. To be honest with the exception of the SOS malfunction early on, I have had zero issues , so I am content until I get my first brake job.
#22
#23
Same Issue
Have been having the same issue with my 2017 Q7. Every time backing out of the driveway the breaks squeal like I don't have any pads on. Taken to the dealership 4 different times and been told its normal but they will clean off the rotors for me. After an hour long discussion with Audi USA the other day, no solution was offered other than to "wait it out" and "not everything is perfect". After spending over $80K on a car thats just over a year old, I shouldn't have to, nor want to, slam on my brakes from 40mph-0mph to try and avoid the embarrassing squeak. Getting ready to get rid of the Q7 and either go for a GLS or a Range Rover.
Lorri Willams Charvat (03-03-2020)
#24
#25
Basic Bed-In Procedure
1. After installing new disc rotors and/or brake pads, perform eight to 10 slowdowns applying moderate pressure from about 30 to 40 mph (50 to 60 kph) without coming to a stop.
2. Make an additional two or three slowdowns applying heavy pressure from about 40 to 45 mph (60 to 70 kph) without coming to a stop.
3. DO NOT DRAG THE BRAKES.
4. Allow at least 15 minutes for the brake system to cool down.
5. While the car is at rest during cool-down, DO NOT APPLY THE BRAKES. If you do, material will transfer from the pads to the rotor and probably give you braking vibration.
#26
If it is a major deal for you I would strongly suggest just getting some new brake pads (Not Audi) pads. If you like everything about the Q7 it will save you thousands of dollars in the end to switch to a quieter pad instead of selling your car and getting a Range Rover. Sorry to say, you will have more problems then just brakes if you get a Rover. BTW my buddy has a RR Sport and he complains about his squeaky brakes all the time, just saying.
#28
#29
