2017 Q7 BRAKE ISSUES, NO FIX IN SIGHT
#42
Yes. It's highly embarrassing and aggravating.
#43
I took it mine to the dealer again, they said they have been told by Audi not do do anything with it until the service bulletin comes out. They are claiming that they are working on a solution.
I would suggest we all call Audi and let them know our frustration.
#44
Thats good to know.
#45
Yeah my dealership mentioned the same thing the last time I was in for my routine service. Pretty much have to live with it until a bulletin comes out. Im sure by the time they figure something out, I'll be due for new pads and rotors.
#46
Mine has slightly over 800 miles on ODO, it's doing it in forward coming out of the driveway in the morning. Yes it does sit for longer stretches of time, but it moves at least once everyday. The squeaking is not that loud yet, but it's audible above the music and closed windows. Goes away after few stops.
#47
Usually this problem comes from not bedding the brakes in properly. Without replacing the pads, you could try having the rotors lightly sanded or scuffed and then bed the pads in properly. Or it might be something else as mentioned.
#48
Yes, the squeaky wheel (no pun intended) gets the grease. We need to hold Audi accountable for these kinds of things or they will never be properly remedied...no one should have to live with brakes that sound like the OP's!
#49
2017 Q7 had brake squeal start at around 9000 miles. Took car to dealer today for state inspection and mentioned squeal to dealer. Dealer confirmed and mentioned that they are seeing this often. Dealer said Audi is aware and they expect a service solution soon. Mentioned that a brake pad with a different composition will be the likely solution. Dealer stated that they would notify me when they have the fix.
#50
More and more car manufacturers install ceramic brake pads as OEM pads. However that also can cause pads to squeak especially when cold, once they warm up, squeaking goes away. Not sure if our vehicles come with ceramic pads by default, but that could explain it.
