2017 Q7 replacement brakes
I apologize if this info is out there, I've tried searching the forum and can't seem to find it.
My 2017 Q7 has about 36K miles on it and needs new brakes. I refuse to put the factory brakes on it because the damn things squeak up a storm. I can't seem to find replacement brakes that are made for the q7, and even the mechanic that Costco says to use can't find them. What suggestions do you guys have that won't squeak and are somewhat reasonable?
Thanks,
JD-
Thanks,
JD-
Thanks,
JD-
Thanks,
JD-
I already did that at 5K miles. They responded, "These are performance brakes. They squeak if they are cold." There is a class action suit about it.
https://thebrakereport.com/audi-q7-b...ction-lawsuit/
What was the fix if you know? At this point in time, it isn't right for me to request free brakes from them because I really do need new ones regardless of the squeaking and my neighbors having complained. I'm just worried that if I get replacements from Audi they too will squeak. I'd just like to know my options for when that happens.
Thanks, I found it and am putting it here in case anyone comes here with the same problem I had. In theory, it is good for 4 years, 48k miles. I should get new front pads.
TSB 2050735/3
TSB 2050735/3
**** Audi and **** the dealers.
I'd buy a goddamn Kia before I'd buy another piece of **** from Audi.
My dealer said the TSB only applies if you have 8mm of brake left, which neither me nor the OP has. So back to the original question: Does anyone know of any replacement brakes that don’t squeal?
