Go Back  AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 / Q8 > Audi Q7 > Q7 MKII Discussion
Reload this Page >
2018 Audi Q7 oil change question, Help!!
Sponsored By:
Sponsored By:
Old 01-26-2019, 05:21 PM
  #21
Originally Posted by htd4555 View Post
OEM Part #: 06E115611H
I bought mine here https://www.europaparts.com/oil-dips...6e115611h.html
htd4555
Thanks. It shows Q7 2011-2015, but it works and is accurate with the newer generation? mine is 2018.
MoInEd is offline
Old 01-26-2019, 05:48 PM
  #22
Yes, it fits perfectly for all Q7 from 2017-2019.
htd4555 is online now
Old 01-26-2019, 06:09 PM
  #23
I meant all Q7 with 3.0 TFSI engine.
Old 01-26-2019, 08:13 PM
  #24
Yes it fits 2018 Q7 3.0T but doesn't read oil level correctly. It reads too much oil than actual.
Joja18 is offline
Old 01-26-2019, 09:04 PM
  #25
So it's longer than it should be. How useful would it be if it's not accurate then? did you check after it was filled after an oil change?
MoInEd is offline
Old 01-27-2019, 04:14 AM
  #26
The MMI shows 100% full when the oil level is at the top hash mark on the dipstick. I used about 7.3 quarts from the last oil change.
Old 01-27-2019, 05:34 AM
  #27
Use it to check whether the oil is dirty or not.
Joja18 is offline
Old 01-27-2019, 07:14 AM
  #28
Keep in mind the second year service requires a brake fluid flush which could be a PITA at home.
Corgiman is offline
Old 01-27-2019, 07:20 AM
  #29
Force-1's Avatar
Dirty oil means nothing. Heat cycles naturally darken motor oil. Modern gasoline-direct-injection engines cause soot, which darkens oil. It's a myth the color of oil can indicate when itís time for an oil change.
Force-1 is offline
ILAudiQ5
Q5/SQ5 MKII Discussion
36
09-03-2018 04:28 PM
Devius
14
03-07-2007 05:34 PM
englsh
10-30-2005 04:00 AM
Quick Reply: 2018 Audi Q7 oil change question, Help!!
