2018 Q7 'wanders'
2018 Q7 'wanders'
hi, i'm new. i have an issue w my brand new vehicle. i am a race car driver and come from that perspective. and also, i own a Porsche Cayenne Turbo, from which to compare. and a ferrari. (and a honda fit). none of which wander.
my new audi 'wanders', that is, does not track straight and true. it requires constant steering input. (when on lane-driver-assist, the electronic intervention repeatedly intervenes).
i immediately suspected front toe-in, or absence thereof.
i took it in and found that the many interventions systems might be at fault in addition to the mild right rear toe adjustment they made. i was astonished to find that these systems are always active and that some of them directly affect steering.
anyway, after the service, the problem persists. i have not driven other '18 q7's and do not know if it's endemic to the breed, although, i find it hard to believe that audi would engineer it this way.
it has 19" wheels and all-season tires, fyi.
any ideas out there? more particularly, do '18/'19 owners experience this at all?
(oh, ps, i hate the steering. it's vague, feedback-less, mushy on-center, etc. electric over-boosted i imagine)
thank you
thank you
Hunter2017 (03-06-2021)
I have driven a number of Q7s and did not had a problem with the car wandering unless the semi-autonomous lane assist/centering was enabled. The latter feature is seriously flawed; so much so that it is more comfortable driving with it disabled. Are you driving with that feature enabled? If so, I may have a suggested fix.
i'm surely hoping your guess is wrong. i'd find it hard to believe (my first audi of 65 cars) that this is the case, but originally, i thought it setup with Zero toe in for gas mileage purposes. i hope not
i found this buried in a ~400pg manual, but haven't yet found a way to disable this (or for that matter other 'driver aids')
Electromechanical steering, all-wheel steering
The electromechanical steering supports the driver's steering movements.
Power steering adapts electronically based on the vehicle speed.
and this, ugh...:
Evasive steering support
Evas ive steering support helps you to steer the vehicle around an obstacle in a crit ical situation. If you avoid an obstacle afte r t he acute warning, t hen the evasive steer ing support assists you by applying slight steering adjust ment to correct ..,
113
*** is tanc e sy s tem s
your steering wheel angle as long as you are actively steering . Evasive steering support is available at speeds between approximate ly 20 mph (30 km/h) and 90 mph (150 km/h).
Turn assist
When start ing to drive and up to speeds of maximum 6 mph (10 km/h), the turn assist uses a braking intervention to prevent your vehicle from colliding with an oncoming vehicle when turning left or right (available in certain countries). The braking intervention causes your vehicle to stay in its lane.
113
Turn assist
and last this, which rjabend may be referring to. i will check this immediately:
Audi active Lane assist
Description
Applies to: vehicles with Audi active lane assist
Active lane *** ist (lane departure warning) detects lane marker lines with in the limits of the system using a camera in the windshield . If you are approac hing a detected lane ma rker line and it appea rs likely that you will leave the lane, t he system will warn you wit h correct ive steer ing . You can override this steering at any time. If you pass over a line, the steering whee l will vibrate lightly. In order for this warn ing vibration to occur, it must first be switched on in the Infotainment system.
i don't get a wheel vibration, though, just wandering
Description
and, again from the manual, it appears that the 'drive mode', ie, comfort/dynamic/auto, affects steering big-time. i will also try changing modes and report back.
i hope to help anyone else who is going down this path
The lane assist and steering wheel vibration will only happen IF the system has detected lane markers. One or both lines will be green in the instrument cluster/HUD. You can turn this feature off with the button at the end of the turn signal.
I know the wandering you’re talking about but I think it’s how Audi sets up the steering.
