2018 Q7 'wanders'
#161
Did you see where a recall is out for loose front shock absorber? Wondering if this could be your issue. https://www.audiworld.com/forums/q7-...orber-2970417/
#162
wandering solved, finally!
after 6 months of trying everything (i drove 7 other cars w electric steering including 2 other q7's, none of which exhibited this behavior), audi still couldn't confirm that it was a problem let alone fix it. they tried but failed.
we love the q7 so much (drove all the logical alterntives) that we bit the bullet and bought a new '19 (ours was the '18) and took a huge loss. and took a chance, a big chance.
guess what? problem completely solved! no wandering. direct clean responsive feel to the steering! not the best implementation of electric (my porsche's are better,eg), but absolutely acceptable.
so, i wasn't losing my mind. the problem was actually with MY car, and they couldn't fix it.
bottom line, we are poorer, but very happy with our new '19 (with 21" pirelli's at that!)
thanks all, saga over
#164
#165
same
i'm the OP. i haven't written an update in a long while as i've been working on this issue with audi.
the short version is: i've now driven a '19 prestige (so, w rear wheel steering like mine) on 21" Pirelli's and one on Continental's. amazingly, the Pirelli car was slightly better than my Pirelli car (slight tire differences?), so audi swapped all the tires to see if that was the tires. The 21" Conti car, i couldn't tell so much, so i didn't reach a firm conclusion there.
upon the tire switch, there was a slight improvement, however, fundamentally is was the same.
that led me to believe that it was actually the car (and maybe somewhat tire related). so my dealer re-escalated it and a zone tech rep went over the car again (they can do absolutely amazing things diagnostically
nowadays (i won't detail everything here, but it is truly amazing...just one example, they can monitor the torque required at different steering angles...etc). and to their satisfaction, they claim there is nothing wrong
with my car...ie, it's within spec.
and that what i am really observing is intrinsic to the current implementation of electric/electronic audi 4-wheel steering. (and yes, they've been all over the video's i posted). they are additionally saying, as have others here, that
owing to my background, i'm extra sensitive to this. maybe they're right?
if this is so, i'm thinking of selling the car. it's very hard to get adjusted to this sloppy, impossible to track-straight, constant steering input, type of appoach. ps, my wife has adjusted to it and is basically fine with it.
this might be my last post on this issue, but if others continue, i ask that you guys please state which model (Prestige?), and importantly, which wheel size, and which tires. (reminder: mine is a Prestige '18, with 21" Pirelli's (non RF's).
#166
it's not the car's steering design. And it may not be the tires. It's toe-in, probably... Here's our story. 2017 Prestige 4-wheel steering. When we initially got it, used, CPO, it had the 21-inch Continentals in a Audi original equipment tire model. It tracked just fine. However when we got home from picking it up at the dealer several hundred miles away, we realized that the two rear tires were so badly worn that they weren't safe to use anymore (so much for CPO) so I picked up a set of 19-inch Q7 wheels and OEM tires from another individual. These were also Continentals. Again no problem with tracking. Then over the winter we put on the same 19 inch wheels with blizzaks. No problem with tracking. Then this week I put the 21 in Continentals, the two that still had good tread, on the front and I bought a pair of slightly used Pirellis for the back. Now the car is wandering all over the place with the slightest Road imperfections and is intolerable to drive. What's the difference between now and last summer when we picked he car up with the same continental's on the front? It has been to the dealership twice for services that required removal of the front bumper, recalibration of the driving assistance systems, and alignment. They said the alignment was a necessary part of the bumper removal and recalibration procedure, which just blows my mind. But again, that's the only thing that has changed since last summer when we were driving with those same Continentals in a 21-inch size on the front ( unless anyone thinks that the Pirellis on the back would have any effect on the steering. I don't think the rear wheel steering has that much of an influence that it would cause the car to wander all over the road). Apparently the 19 inch wheels and tires, being a lot narrower, we're not as sensitive to Road imperfections. So we didn't have a problem the entire time the 19 inch wheels and tires were on the car. But neither did we have a problem with the 21s until after these last two service episodes! Wandering is generally caused by insufficient front toe in. I got a rough measurement at the front wheel tread using a tape measure and it appears to have about 1/8 inch of toe in measured that way. This is probably pretty close to what it should have. Perhaps when we originally picked the car up last summer it had more toe in and when they aligned it at the dealership they took out some of that toe-in. Toe-in is easily adjustable by lengthening or shortening the tie rod ends. you have to adjust each one the exact same amount to keep your steering wheel pointed straight. The stealership is 3 hrs away and the last thing I want to do is give them more of my money, so I may just make a slight toe-in increase myself and see what happens. Or take it to my more local alignment shop.
worst case you could go to a specialty alignment shop, something that does high end and/or track alignments. I am sure they could straighten you out.
I have been lucky because I have recently had a full alignment last summer due to a windshield replacement... but still the car is driving just as well as it was before the alignment....
silberblitz
04-03-2006 01:54 PM
sozdemir
02-08-2005 02:54 PM
90quattrocoupe
02-22-2002 01:07 PM
