ACC downhill
on my Q7 when i set the speed to say 80km/h..... when i am going downhill...in other cars, the car would normally speed up to faster than 80km/h..... but the Q7 stays on 80..... no matter how steep tbe descent. so my question is..... what is the car using to slow down? brakes or engine?
It uses the gearbox to downshift, which you may be able to pickup on, and brakes.
Originally Posted by Gani
(Post 24999631)
Cars use both downshifts and brakes |
Originally Posted by BigKutta
(Post 24999639)
In all of my recent cars, they will maintain the speed on a downhill also.
Okay so you are saying then that ACC is bad for brakes ?
(Post 24999690)
(Post 24999698)
Not necessarily, but if you use the ACC a lot and have the distance between cars set to a minimum, the brakes will certainly get more use. Just like when driving without ACC...if you are an aggressive drive always tailing people, you'll use your brakes more
(Post 24999690)
With my previous car (my wife is using it now), Audi A6 (C7) I changed front brake pads for the first time at 100'000km. And rear brake pads at 120'000 km (car is already 6years old). And I think they could go another couple thousand km, but front was changed along with front wheel bearing, rear in last 120'000 km service last week. Besides, change of front wheel bearing is the only repair job done on my Audi A6 at 120'000 km. Very, very reliable car. Will see, how Q7 will keep it's reliability record. Now for 27'700 km excellent record. |
The etron has a cool feature, it uses the nav to slow in turns or tight corners and uses the regenrative braking to slow the car down, it serms. However, my car accelerates 1-2 kmh downhill in contrast with op observations.
(Post 24999698)
