ACC and Traffic Jam Assist
Now that I have tried my car a few times in traffic, I have some thoughts.
TJA is nice when it is working, but it takes mental energy to remember or check if it is active.
There are so many things that make it not active.
1. Hitting the brakes.
2. Going over 40 mph.
3. It seeing cars coming at you on a non-divided road.
4. It not seeing lines.
So you can never relax and let it do its thing, as at any given time, there is a significant chance it won't work.
Another issue - shen you have normal cruise control, it makes sense for it to default to your current speed when you engage it. But with ACC, and if I am in traffic going 20 on a 65 mph speed limit road, I don't want it to turn on and be set for 20! I want it to turn on and be set for the speed limit, or the speed limit +- some offset.
So there needs to be a setting where AAC could be either activated at the current speed, or at the speed limit +- some offset -- especially if the speed is currently limited by the radar seeing that I am in traffic.
I know. That is bad. If I am on a highway with a 65 mph speed limit, but stuck in traffic going 20 mph, and turn on ACC, I want it to come on at the speed limit, not at 20 mph. This is especially true if it was previously just set for 65 but disengaged from having to hit the brakes. The cars knows the speed limit. Why would I want to drive 20 on a road where the speed limit is 65? Should be a user preference but defaulted to off.
Depends why it is off. True if it is off because it can't get a lock. But if it is off because a car just cut in front of you and you had to hit the brakes, then AAC is turned off. I guess they have to do this, or else some person will not know how to turn ACC off if it doesn't go off from hitting the brakes. I will just have to learn to resist hitting the brakes. But twice today cars cut into the gap in front of me, and the ACC didn't see it happening. Personally I don't cut in front of people if it will require them to react to not hit me! So it is annoying when people do it to others.
If you had it set at 65, then hit the brakes, pulling the stalk forward will resume it at 65 again.
I see. I should have known that because that is how normal cruise control works. Thanks.
It is just that I never used my normal cruise control because, well, it was just too annoying to always be running up to other cars.
As little useful as normal cruise control is, ACC is the total opposite. It is outstanding.
How come when the car comes to a complete stop, sometimes it moves again on its own when the car in front of me moves. Other times I have to tap the accelerator?
Does it just have to do with if it is in ACC or TJA mode?
BTW, I don't mind *** and don't find the restarting of the engine to be bothersome.
Not that taxing. The TJA symbol comes up in the dash better yet comes up in the HUD if u have a prestige. At first i was confused but now It such a seamless operation to me as the car transition between tja and acc. Setting the speed is easy too by pushing or down on the stalk. You can have the car change the speed with the speed signs but not sure how that works with TJA engaged
You can increase the set cruise control speed on the left lower stalk by 1's or 5's depending on how far you push it.
This car has a ton of features. It behooves you to spend the time to read the manual to make sure you're getting the most out of it.
