Adaptive Cruise: Set Speed Limit with Tolerance
Has anyone figured out how the Set Speed Limit with Tolerance works for the Adaptive Cruise Control? As far as I can tell, setting it to "with tolerance" seems to work the same as just setting it to "on".
Menu > Vehicle > Driver Assistance > Adaptive Cruise Control > Set Speed Limit (off, on, with tolerance)
For example, if I'm cruising at 70 in a 65mph zone and the speed limit changes to 55, the cruise resets itself to exactly 55, not 60 (+5) or 59 (+7%). It seems to behave this was whether the option is set to "with tolerance" or "on".
Anybody else experience this?
I sure wish there was a way to do what you are saying.
They way you have laid out is the logical way to work. However, tolerance means that the cruise control won't do everything possible to keep the speed at 65 mph, e.g.. In other words, with tolerance in certain conditions it may let it go up to 67 and down to 63 in order to be more efficient.
Part of the confusion (in my mind anyway) may have stemmed from the other setting where you can set the speed limit warning to +0, +3, +5 or +10. Sure wish the ACC speed limit had that option.
That makes total sense. I guess I'll just turn it off then, since it's pretty annoying for it to reduce all the way down to the speed limit rather than something like 5 over.
Another thing is a simple shortcut to Apple Music. Perhaps holding a certain button down.
Speaking of shortcuts, the manual says that you should be able to program Nav destinations and Phone numbers into the preset buttons, but so far, I've only been able to get it to accept radio stations.
The best I can tell, our 2017 Q7 Prestige does not come equipped with ACC. Am I wrong?
My '13 S8 has ACC, which makes me quite familiar with the system.
The new Q7 does not have a "set distance" roller or toggle on the cruise control stalk. In the MMI, Pre-Sense is available, but not ACC.
Have I been hoodwinked?
If you do have that package - the distance control switch is no longer on top of the cruise control lever - it's a toggle switch on the face of the lever.
Missing Driver Assistance Package
Well, I can't speak to your having been hoodwinked. But the Order Guide (attached) clearly shows that ACC is part of the $2,400 Driver Assistance Package which is optional, not standard, on Prestige. If you expressed an interest in ACC, your dealer should have pointed this out to you.
We ordered the 21"wheels with non-run flats. The car came with the 20" wheels and run-flats. I think that lengthy discussion/negotiation with the dealer distracted me from being more careful.
As I examine the original order sheet that was confirmed as accepted, I find the PCU for the Driver Assistance Package is present, but PCU is not on the window sticker or the car.
Serious discussion with the dealer to follow. Not happy, here.
You are correct, of course. I am just getting around to going through the owner's manual and learning the difference between the MMI on the Q7 and the MMI on our '13 S8.
