Is "Android Auto" useful?
#21
Right now you cannot use the Assistant via AA to send a message via text and have it use the Google Voice number as the sender address. The team does know about this bug.....
#23
Hi Scoopman, I am having problems with Tune In getting stuck after I get back in the car, so it sounds like there is a miscommunication or lack of resume (it gets confusing, and stops playback, says "buffering" forever). When I first start driving, it works fine, no problems at all. Once I get out of the car, and get back, it misbehaves.
Also, at this point, it causes it to crash so bad on my phone I can't even end the application easily. I have to force close it. Is there a known bug with Tune In on 6.0.1 or is there something else I can try.
#24
#25
Thanks Scoopman, I'll try other apps, it's just that I've been using tuneIn for many years and it has vast number of stations around the country. Most of those stations have their own apps but not available in AA or in other consolidated streamers.
I'll check if MyTuner has similar selection and give that a try.
#26
Hi Scoopman, is there anyway to prevent MMI AM/FM Radio from turning on while Android Auto is buffering or while changing stations? Is this a bug, or is there a way to go around this?
#27
Hmmmm, I'm not sure what you are describing. I don't have anything like this happen on my S5. I know it might be difficult to do (you need another phone) but could you take a short video of what's going on to help?
#28
When I am listening to a station on TuneIn Radio, if I change channels (or hit next in favorites) it stops playback, switches stations and starts buffering. Sometimes (I don't know what triggers it) I hear the FM Radio in the channel I was last listening to, until it completes buffering, then it starts streaming.
It also happens when I hit the stop button in Tune In. Instead of just going silent and staying in AA audio input, I hear the FM radio. This sounds like a normal operation, but it should not be doing that if the app is loading/working/buffering, etc.
Same thing happened with "MyTuner Radio" app as well. Will try to replicate when I get back to my Q7.
#29
Sure, I'll try tomorrow.
Questions:
Only happening for you with TuneIn?
Is the MMI's audio source you last used before you switched to AA's audio the FM radio? (eg if you had selected Sirius then plugged your phone in, would you hear Sirius instead of FM when TuneIn is buffering?)
#30
