Audi q7 E-tron air suspension lowering
Hi
I have a 2017 Audi q7 Etron. It has standard air suspesion(not the sport air suspension that is available also)
I wonder if someone can help me out to lower the car a bit using VCDS?
10-15mm if possible.
Best regards
Best regards
I'm not sure if they will work with your particular suspension, but have you contacted Airmatic in the UK? They have links available which allow you to infinitely adjust the ride height within a range.
I am pretty sure its possible to lower the standard airsuspension using VCDS. A mechanic told me that its possible to lower up to 17mm on each Wheel. Then it will be more similar to air suspension sport which is 15mm lower I thin
