Back seat rattles
Back seat rattles
Hi Guys. Just got my 2017 Q7 Premium Plus for little less than a month. Everything has been great until... After some snow driving in the past week I started to hear rattle noise from the second row seat area. It 's kinda obvious when the car passes thru uneven surface.
Not sure where it's coming from exactly but seems like it's the back seat rails. I did some simple tests to eliminate the possibility from the cargo cover or seat belt.
This is my first Audi and be honest with you I'm not too happy about it. I don't know if it is common for a $65k+ car. Had notified the dealer today and hopefully they could fix it. Will update later, thanks.
Have someone ride in the backseat to see where its coming from. Once the source is located that's 9/10's of the battle then service will easily do the rest with out subjecting your brand new 7 to lots of testing miles to determine the location of the noise
Have had 2 - Q 5's & both had this issue. Took them in & after they replaced the seat frame never had the problem again. Someday Audi will solve this so you don't have the issue at all.
I have a rattle behind the front seat and haven't been able to locate it yet. It only happens occasionally which is very frustrating. It's usually with someone in the passenger seat so the added weight must help trigger it but my wife hasn't heard it. Her hearing isn't as good as mine.
What's funny it's that this time the back seats remained silent.
Got mine in the shop for door rattling or plastic popping noises after snow day. The shop said it's due to the plastic or rubber seal that wrap around the doors. They applied some lubricant on it and its gone for "now". I dunno how this possible for such luxury brand. Regarding the backseat rattle, I posted something about it. I think the title is "new noise from dash board", but it was actually from two side seats on second row. You can fold one side down and hit the middle seat horizontally from top to bottom to reproduce the noise that way. My car is still in the shop and they are trying to find a solution for the second row seat. The noises were like a metal spring recoiling like sound (new) and constant whistling noises (spring rubbing inside fixed). Hope this helps.
bac2h
9
07-25-2011 01:01 PM
