A rumor to improve oil consumption and transmission
To be clear, it's a hearsay from my friend without any test.
Recently, I told my friend who self-declared a VAG expert about the oil consumption issue for the Q7.
He told me VAG vehicles are designed from racing car and better driven with high RPM.
If people drive in a city, they should use S mode or manual mode to keep engine in high RPM, better change gears after 3000+ rpm.
D mode is only good for high speed driving like highway. The low rpm will caused low temperature in engine so that it burns more oil.
I forgot why this also cause damage to DSG transmission in low rpm. It's a long BS story
Anyway, does anyone hear the similar theory about the sporty driving habit is better for VAG engines or it's just a crap from my friend.
I would like to hear some opinion to decide if I should slam his face . Thanks
Can't imagine this would make any difference at all. In fact it might increase consumption. I'd guess that Audi lets the engine run a little "loose" to reduce internal friction and increase fuel,economy. Audi engineers would be well versed in allowable oil,consumption vs contaminating the catalysts which is the major problem with excessive blowby.
I'm calling hogwash to that idea. Thermostat keeps the engine at an acceptable temperature for optimum efficiency. Running higher throttle openings actually cools the engine (due to more air being pushed through it).
I think you should slap him in the face for the BS, but still drive your ride hard (just because it's fun, not that what he said had any technical merit. )
Audi Q7 Prestige'18 Owner
Seems like your friend might be speaking from lack of experience with Audi.
Rumor has it that it burns more when the engine is cold so getting it hot quickly might have some truth to it. Frankly I've noticed the engine will stay cold longer if you hit traffic and can't get to speed quicker during city commute
Note that if you leave the car in S mode while on the highway, it still shifts to low RPM as long as you are not accellerating... so leaving in S mode on highway doesn't seem to consume any more gas than putting in D mode on highway... S mode only seems to change how things accelerate/decelerate, thus making the car less efficient (gas wise) than "D" mode.
