Base sound system is terrible, any suggestions?
#11
Thanks for the great suggestions. I'm looking into a stealth upgrade that would replace the 6" woofer with a shallow 8" sub and possibly the amplifier. The amplifier seems to be hidden, maybe behind a side panel. Would anybody with a Bose amplifier be able to confirm if that amplifier is visible (there's an empty space where I suspect it may go)? A picture or the layout and part number would be a bonus.
#12
@CrankTT - I am in agreement with you. I absolutely love my Q7 but I am disappointed in the base sound system. I didn't even think about testing it out when I bought my Q7 assuming that Audi would have kept everything in the car top notch. My bad.
I contacted Audi USA today, not sure what I wanted to get out of it, and told them that I am disappointed with the sound system. They asked if I have taken it to the dealer to have it checked out. I told them I have not and that I do not believe that it is defective but rather a sub-standard sound system which I would not have expected from Audi. They said that they would document my complaint so that it can be shared with the appropriate internal resources.
P.S. Can't say anything about default sound system.
#14
After doing some digging, it appears that there is no separate amplifier for the OEM system (non-Bose, non-B&A). The amplifier seems to be integrated into the unit inside the glove compartment.
This will be harder than I thought to retrofit (unless the same harness is used and extra wiring is hidden). I'll post an update if I figure anything out.
Is there an emoji for 'regret not buying Bose upgrade'?
#15
Audio in 2017 Q7
Any idea if Audi can improve the standard system, or do I need to upgrade?
Thanks.
#16
Same issue: just got a 2017 Q7 last month and love everything about it except the audio. I also made the mistake of not paying for an upgraded sound system, assuming the standard system would be of high quality. Instead, I find the bass is weak and distorts at relatively low volume. I've tried adjusting the bass, treble, balance and fade, and also tried different kinds of music but haven't found anything satisfying, let alone worthy of a vehicle of this calibre. Worse, I had a rental Dodge SUV for a few days recently and the audio sounded much richer.
Thanks.
Thanks.
#17
I made the same mistake of not upgrading the default speakers in 2017 Q7 premium plus and found the sound quality terrible. It's much worse than my previous 2015 Passat which cost about $30K and has Fender sound system.
Why does Audi put such a poor quality sound system as default one of a $65K+ car?
#19
Poor quality base audio system
Had no idea that the base audio system in a toyota tercel would sound better than the base system an Audi Q7. Distortion even at 50% volume, depending on what type of music is playing.
#20
One thing I have found that is an easy fix for improving the sound in any Audi is turn the surround setting off. I find it's accenting the highs to give the false sense of surround at the expense of the mids and bass. I've also found that depending on which system you have that setting the sound focus to the front also helps and even then adjusting the front to read fader in some cases. I've tested this on a 2013 Q5 with B&O, 2014 A7 with Bose and a 2017 Q7 with B&O. I've found by doing this the Blose does not blow as bad as it did before tweaking.
