Bike rack
Bike rack
I have a two bike platform rack. My Nissan Rogue's blind spot misfires sometimes due to the bike rack in addition to hindering visibility in rear view camera. What's your expeience with Q7? Do the parking sensor or blind spot sensors handle bike racks OK?
This may vary on the exact rack itself, but when I have my 1UPUSA hitch rack installed, whether with 2, 3 , or 4 bikes, the blind spot monitoring still works well. My previous 2012 Q7 would deactivate the blind spot monitors sometimes half-way through my drive, but I have not had that happen with the 2018.
The rear parking sensor, on the other hand, of course beeps when I go into reverse, thinking that there is something back there. That persists when going forward slowly since the sensors remain active. However, as soon as I pick up speed and the sensors shut off, it is not a problem. They also do not automatically re-activate when pulled up to a light behind another car, for instance, since that would be activating the front sensors and not the rear. So everything works as good as could be expected considering the rack and bikes are back there. Of course the camera view is limited, so you do have to be careful and use your mirror more when reversing.
No issues here other than the beeping in reverse and you could mitigate that by installing this https://www.etrailer.com/Wiring/Tow-Ready/20142.html but that does disable some safety features because the car thinks you are towing something
Just to clarify for the OP, since he specifically asked about blind spot monitoring. Using something like above, making the car think that you are towing something, will then disable the blind spot monitoring. I would rather have beeping for a little bit while reversing (turn the volume down a bit) in order to still have the blind spot monitors.
David_TT225QC
08-06-2008 07:54 AM
