Brand New 2018 Q7 3.0T PP Low bass like sound from engine
Old 04-20-2018, 06:10 AM
Rals's Avatar
Default Brand New 2018 Q7 3.0T PP Low bass like sound from engine
Hi All,
I just bought a new Q7, and has 500 miles on it now. I bought here in NH, and i'm noticing a low hum or deep bass like sound coming from the engine. Before you say, do a search - I did and found bearing issue as one possible problem (that seems likely and maybe unlikely at the same time) and issues with Supercharger clutch. It happens at low speed, where the car has a super deep sound. Has anyone experience this? I'm skeptical being a supercharger issue, but this is my first time owning a SC so i don't know.
Thanks,
Murali
Old 04-20-2018, 06:17 AM
BigKutta's Avatar
Originally Posted by Rals
Hi All,
Thanks,
Murali
Can you record a video and post it here? Its hard to tell if this is normal or not based on your post
Old 04-20-2018, 06:23 AM
Rals's Avatar
i will try recording during lunch - skeptical it will come through clearly.
Old 04-20-2018, 06:26 AM
BigKutta's Avatar
Most likely not, but its worth a shot. I can record one and post it here as well to compare
Old 04-20-2018, 06:29 AM
BigKutta's Avatar
When do you hear this? Accelerating from a stop? 0-30? 0-60?
Old 04-20-2018, 06:36 AM
Rals's Avatar
Low speeds, like 50 mph or less I hear it the most. It's like droning sounds of sub woofer. Thanks for your help on this!
Old 05-14-2018, 05:42 AM
Jwillads's Avatar
Default Similar sound from wife’s 2018 Q7 3.0
My wife’s car is making the same noise. Dealer just replaced the wheel bearings and noise is still present. Noise is like a dull groan at slow speeds.
Old 05-14-2018, 05:45 AM
Rals's Avatar
How may miles on the car?
I actually think it's from the run flats, because the noise has dissipated quite a bit.
Old 05-14-2018, 05:46 AM
Jwillads's Avatar
7500 miles or so.
Old 05-14-2018, 08:00 AM
Rals's Avatar
7500 miles or so.
Hmmm...it seems odd that a wheel bearing need to be replaced so soon, and I thought that doesn't sound right either that would be the cause.
My only conclusion is the tire breaking in, that's when i really hear it at low speeds. Do you have a 2018?
Quick Reply: Brand New 2018 Q7 3.0T PP Low bass like sound from engine
