Can I set the mmi to be off by default?
I pretty much only use it for the parking cameras. Any way to have it off on start until the parking cams are triggered? Or even down on start?
do you want to turn the MMI off or do you want to turn the screen off? It sounds like you want the MMI to be operational, but you asked about turning the MMI off.
i now want the screen off but the audio on. I just put in a tv for the kids and I need to feed the audio through the aux.
Can you lower your screen after starting the car (if your Q7 was made prior to May 2018, it has that functionality)? I am able to use audio (ie Car Play) with screen retracted.
HOWEVER, to your question - it seems that the same button that I use to retract the screen you can use to turn the display off (at least, that's what the first post in that linked thread says). Try it - the button is the top right
https://www.audiworld.com/forums/q7-...tract-2953440/
Unfortunately, it's not possible as Audi removed that capability sometime in May 2018 to comply with US backup camera regulations (see thread below). So far, no one has been able to bypass this though OBDII or similar coding. Q7's manufactured prior to May 2018 still have that capability (there is a console button all the way to the right to lower the screen - you don't push it down manually). My Q7 was built in March 2018 so still has that functionality.
StraySheep
TT (Mk3) Discussion
26
01-04-2023 03:04 AM
cranialsurge
09-27-2018 04:01 PM
InTTruder
Southeast Discussion
05-27-2008 01:13 AM
