Dashcam installation
#101
Thinking about using the Rexing hardwire kit to tap into the mirror assembly for my A119 on the Q7. Does anyone know if the transformer is small enough to be fitting inside the cover?
#102
Dunno but don’t know why anyone would want a mirror tap since it loses power when the car is off. If someone breaks into the car when it is parked, there is no hope of having video of them.
#103
Why not just run down to the fuse panel in the end of the dashboard? For me, that was actually easier than monkeying around with the mirror housing covers.
#104
Thanks. I already have my radar detector hardwired going to the fusebox by the foot rest as there are no switched spots on the left of the steering column....
Can't say for sure, but I kind of doubt it. Plus the cable from the transformer to the USB plug is very long (approx 10'), so that's a lot of cable to hide. It would definitely not fit in the mirror housing. You would have to try to shove it up into the headliner.
#106
Found another hardwire mini usb
It's a left angled mini usb perfect for the A119 so you don't have to loop the connector when coming from the headliner. It's also a much shorter wire.
#107
https://www.amazon.com/gp/product/B0...83RV6W5M&psc=1
#108
Just mounted my front camera. I mounted mine on the passenger side of the mirror housing. I popped the large center trim piece(really easy) and ran the wire up to the headliner, through the mirror housing, and back into the headliner. Put the trim back on and it's nice and clean... Getting around the corners was a pain, but I was able to get it done... The only unresolved issue I have was with the seam between the headliner and the a-pillar. I could not get my wire in there no matter how hard I tried. I may give it another shot tomorrow... Everything else worked out. I just have about 5 inches of exposed wire running along that seam...
#109
#110
Interesting. I found that spot a "little" tricky, but not terribly so. The trick was to get a nylon pry tool under the a-piller trim piece and pull it out slightly, then while holding it out, follow with the cable closely behind, shoving it in with another tool. The a-piller trim overlies the headliner, so that's the one you pull out. I didn't want to pull it out too far (or remove it) because the airbag is under there close by. But I didn't have to pull it too far.
