Default phone view Virtual Cockpit
The startup screen setting only affects the graphic displayed on startup. I don't think anyone has yet found a way to change the default tab on startup. You can, however, disable tabs you don't use so there are fewer to rotate through to get to the one you want.
Through the menus or obd11?
It's been a couple months in this post .... just figured I would see if anyone found a solution for this? Hate that the Full Directory shows up in the Phone Tab every time you get in the car instead of the Favorites.
