Driver assist features
#11
I have a question here for using the ACC.
As I tried these days, it does very good on following the traffic, slows down and speeds up again, but I still have concerns about the traffic merging. When a car driving next lane trying to merge into my lane, by seeing the turning light, human (at least me ) will notice and stop pressing the accelerator pedal to give more space until the merge finishes, so the riding would be smooth. But as I noticed for Q7 ACC, it still keeps following the traffic closely (I guess it could not know other car's lights) until the merge starts, then it would be a noticeable break to slow down, that makes me feel a little bit... aggressive.
What do you guys usually do for that case? Cancel ACC and enable it again after merge (sounds annoying)? Change the ACC distance and change it back (also annoying)? Or just let Q7 play by its own?
#12
#13
This is a real thing. The car does not see others trying to merge in, and will not make room for them. Best to do what Bozman said. I tried doing nothing, and if a car squeezes in, the Audi will eventually see that car close in front of you and put the brakes on so hard that a car behind you rear-ending you is a real possibility.
#14
#15
I keep ACC set for min distance, but I could leave it at the default. But then tons of cars would always cut in.
BTW, the HUD height doesn't seem to be stored in the driver 1/2 memory. I think it should be.
#16
#17
I like the min distance as well. FYI, you can code that as the default.
#19
It even creates a new menu to set it in the MMI.
I don't have exact the obd11 settings, I'm sure it's been posted a few times.
This may be enough to get you there:
Q7 (4M) Coding
Scroll down to:
Adaptive Cruise Control Distance Regulation Set
Someone may have the exact obd11 coding to post. I didn't document all my changes.
Q7 (4M) Coding
Scroll down to:
#20
