Engine coolant bottle almost empty
#21
timely post. our 2017 w/ 36k miles had the low coolant light turn on last week. turns out the coolant tank was low. i topped it off w/ some 50/50 g13 coolant and will be taking her in tomorrow. also didnt observe any leaks or anything.
#22
I reported the same issue on my 2017 Q7 at the 10K service. The dealer did a pressure test and said nothing was wrong.
It happened again just before 20K. When I brought it in for the 20K service, I reminded the service tech that the issue persists, and that this is the second time I'm reporting this issue so another a pressure test won't cut it. They found a leak around the water pump and replaced the water pump, some seals and hoses, and I haven't had the problem since. Now at 51K.
#24
audi found a small leak around the tstat. under warranty the tstat and water pump will be replaced since apparently these are one unit. reading the replies here, this is not an uncommon issue.
#25
Thanks for all the responses. I have my appointment the second week of January. The level has been going down VERY SLOWLY since refilling, so I'll keep watch on it but shouldn't be an issue going a few more weeks. It's helpful to know the water pump/thermostat is the most likely culprit. That way if the dealer says the pressure test was negative, I can ask them to keep looking.
(I'll try to have them do the top view camera TSB at the same time.)
#26
This is why I LOVE this forum! My Q7 is in for service for the coolant leak. The dealer sends "service video" where the tech is doing a walk-through of the car inspection on the video (kinda cool actually). Near the end he states that he did not find the leak and pressurized the system and it held for a certain number of minutes. He then said that sometimes the coolant level just needs to settle on new cars. I called the service advisor, but his phone went to voicemail. I left a detailed message saying that having the whole reservoir of coolant disappear and having the level go down a little again over the last 1000 miles is not "the coolant level settling". I mentioned the water pump and t-stat and the fact that the pressure test wouldn't necessarily reveal that. Hopefully they are looking into it further.... I'll call again in a bit. I appreciate the responses here so I know to keep pushing them...
Question: how accessible is the water pump/t-stat in order to visually inspect it?
#27
#28
Just spoke with the service advisor and he says the water pump and t-stat were indeed inspected and no sign of leak the or anywhere. He insists that there can indeed be that much air in the system... Argh.
I guess I'll travel with a bottle of already-diluted coolant in my trunk, especially for long towing trips. If it continues, I'll have them check again at 20K service.
#29
#30
Yes, the car was serviced at that dealer for it's 10K service this past summer. I suspect the coolant was low at that point, but not noticed - perhaps the engine was warm when they looked, so the level appeared higher. The night I got the notification it was REALLY cold, and I have noticed quite a swing in the level based on temperature. I have done roughly 1,100 miles since filling it, and it has gone down but rather slowly. When I picked it up today, it was quite a bit over the "MAX" line, but the engine was warm. I'll be curious to see what the level is tomorrow morning with a cold engine. If it is over "MAX" when cold, I'm going to remove some fluid so it is easier to track and so that by the 20K service they don't say that the "level still looks good" just because it started overfull.
