Fog lights
Apologies for my laziness to check my manual. I was driving in fog today and couldnt find where to turn on fog lights. I just put the lights on auto. Will that do the trick?
The two buttons left of the light dial. Top one is front, bottom one is rear. Auto will not turn on your fogs.
There are no actual fog lights on the new Q7 - not like the previous generation.
There is a button on the headlight switch panel (left side of the rotary switch - top button with a headlight pointing into a cloud) that turns on "all weather lights". These are not separate lights, but rather "automatically adjusts the front lights so that there is less glare for the driver from his or her own lights" (per the manual). There are rear fog lights controlled by the bottom button below the All weather light switch. If you have a Prestige with all the Driver Assist goodies those little round globe things in the front facia where you would expect fog lights to be are radar sensors - not lights. |
thank you ;-)
Originally Posted by Cadx6
(Post 24861189)
There is a button on the headlight switch panel (lefts) side of the rotary switch - top button with a headlight pointing into a cloud) that turns on "all weather lights". These are not separate lights, but rather "automatically adjusts the front lights so that there is less glare for the driver from his or her own lights" (per the manual). There are rear fog lights controlled by the bottom button below the All weather light switch. If you have a Prestige with all the Driver Assist goodies those little round globe things in the front facia where you would expect fog lights to be are radar sensors - not lights. See pic without fog switch turned on and see the other turned on. https://cimg9.ibsrv.net/gimg/www.aud...a8b58945a.jpeg Fog lamps not activated. https://cimg0.ibsrv.net/gimg/www.aud...5f080da6e.jpeg Fog lamps activated. |
Yes, there are actual fog lights. They seem to illuminate mostly out to the side. Also, they illuminate the direction you are turning when the headlights are on and you have your turn signal on. That feature was unexpected and is pretty cool.
^^ sounds like the perfect post for the hidden gem thread
Originally Posted by Rheagar
(Post 24862043)
(Post 24862043)
Yeah really neat function. I love it. I actually noticed the right side fog lamp turn on after I turned my steering wheel slightly to the right in my garage. I didn't even have my turn signals on. Driving at night, I love the wide coverage they provide ! |
