FRONT LIP options for the Q7?
Bsuermik (08-21-2023)
#16
Hi guys,
has anyone seen any front lips for the Q7?
I think the front end needs some extension at the bottom and a front lip could fill that gap. Pic of my grey car attached.
I found only one Q7 on Instagram that had a front lip installed but I have no idea where it's from. It's the red one below.
Thanks,
Matt
Thanks,
Matt
At night.
Different combinations. Of course, you can turn all lights off while the engine's still on if you turn on "Daytime running lights" in MMI.
One more picture shared.
#19
Before you go for it, something you should know in advance.
Make sure your front bumper has proper secure locations, three actually, to hold this lip set. Believe me, it has some weight. A little cutting job applied if it's necessary.
Not sure if it will work with HID. For LED, you need a certain type of control unit or you'll miss two (or three) pins for the lip.
After all the hardware job is done, you also need to modify the software.
By following all the original standards, you'll need to order more than 20 items and receive more than 60 parts for this project.
