Front rotor aftermarket replacements?
#42
I'm at 42k miles. Front brakes are completely done. Rotors were scratched heavily at around 40k miles. Audi would not replace brake pads without replacing rotors. They also said the OEM rotors are too slim in depth, and would not sand down the surface to accommodate the new brake pads. Hence, I started this thread.
#44
ok so I cross check the tirerack centric rotors (12533158) and found out that tire rack has the wrong picture associated with the rotors. if you check out the same rotors at rockauto. it shows the OEM style rotors. even when i googled the part number, the image come up as the OEM style rotors. anyway you can try to order from tirerack and see if it is indeed an OEM style rotors. if i'm not mistaken i read somewhere that audi has started using centric parts for the brake systems.
#45
My order from Adam is on hold. Front rotors are not available at the moment. He can use the OEM rotors as the base rotor, but I didn't want any OEM. There is no estimate when aftermarket front rotors for the 4M Q7 will be available. I'll wait till end of May, then I might have to settle for the modified OEM rotors, but it'll cost me an extra $450.
https://brakeperformance.com/brake-r...IaAuPvEALw_wcB
#46
Any update on your order? I was about to pull the trigger, then came across these from Brake Performance. Anyone use or would recommend? Looks like a 200 saving over Adams for me (was considering the street F&R with stoptech front only from Adams)
#47
https://audi.bernardiparts.com/oem-p...MtMGwtdjYtZ2Fz
