Hatch Rattle
Hatch Rattle
All - I just took delivery of my 2019 Prestige and I couldn't be happier with it - save for the rattle coming from the rear.
I have noticed that there seems to be a rattling noise generated by the passenger side of the rear hatch. Like there is a disconnected wiring / plug that is flopping around on rough roads.
Has anyone had a similar experience? My wife also has a 2018 Prestige and we have not experienced anything similar in hers.
Any info would be helpful. Thanks!
Yes, I should have mentioned that. I checked to make sure it was seated correctly when down (retracted) and also drove the car with it extended. Neither position seemed to make a difference - unfortunately...
I assume you've also looked under the trunk floor to make sure nothing is loose over there. One area where I always have issues is the second row seat belt. If not tucked away properly after use, it tends to get stuck between the second row and the C pillar, and rattle/knock. This occurs on both sides and sometimes I have to stop the car and fix it.
Had a similar issue... rattle (from the hatch area) whenever the vehicle was torqued over uneven rough roads... While in for service they checked it, couldn't duplicate but did find a TSB related to the concern.. "Found the BUMP STOPS in rear of vehicle needed to be re secured" I haven't heard the rattle since I got it back from service (about two weeks ago).. maybe the same issue? Easy one to check on your own...
Hi BigKutta - thanks again. Yeah - I made sure everything under the trunk floor was secure and also checked the seat belts for 2nd and 3rd row to make sure they weren't swinging around and banging anything. It is definitely something in the rear hatch area. I actually sat in the back while my wife drove to try to narrow down the possibilities, and it is definitely coming from the rear hatch or adjacent underneath...
we just had a rattle on the ruff roads that ended up being the head liner????? I know I though the same thing. they called Audi USA and they recommended adding some felt and now it seems ok. but its only been a couple of days.
All - it took the dealership five days to figure it out, but apparently the rattle was due to an insulation issue between the body and the rear tail light module. The shop foreman contacted Audi and they had a "prepared" response for him on how to remedy the situation - so I am guessing I am not the first person to deal with this. Result! All is good now. Thanks everyone.
