lane assist experience and issues
I'm still collecting data but thought I'd start this thread to seek others input. Overall experience is positive but concerned about some behavior that I'm trying to correlate to something but not yet sure. (im in USA)
Issue #1: Lane assist randomly resets itself to 'early' after I set to 'late' in terms of when it reacts, engages. Can't determine when this happens, but its happened at least 4 times the past 2 months. Issue #2: Even in 'late' its a very strong pull....definitely not as early as 'early' but still very strong. Most cases this is a good thing but often times it pulls me in a direction I dont want to go. Example: HW driving past an exit..solid line road marker on right disappears and turns into dotted line or no line at all (more often). The car wants to go right and not follow highway (my intention was to continue on HW). Second scenario is similar to above but this time my intention *is* to exit using the blinker. On occasion (maybe 1 out of 5 times) even with the blinker on, it wants to pull me left and not 'want' me to take the right hand exit....again, even with blinker on. Anyone have similar experiences? |
I have had somewhat similar experiences to #2, not #1. I used to have mine set to "late" but actually now prefer "early". With late, I felt like I was being ping ponged at times. With early, I have found that it does a better job of driving itself. I tend to use it on the highway and turn it off when the roads get windy.
Gives me issues if there is suddenly a turn lane on the right where there is a large opening prior to the start of a solid white line. It wants to go into the turn lane. |
Originally Posted by baltfan
(Post 24788970)
I've also experienced issues with lane assist. In general it works well but sometimes a bit flaky. One instance was it kept trying to drive the left wheels on the solid yellow line at low speeds (Congestion assist on).
I used it today for about 100 miles. It really hugs the left yellow line but gives more space on the right side which was white. Problem was the drains on the left side of the highway. Dashed lines make it a little jittery, especially in a curve. The ability to read and adjust ACC for a downhill s-curve at highway speed was impressive. It's not as good as Tesla's system but still helps reduce driver fatigue a great deal.
Zurichch: you pretty much describe what I experience. In my case for #1, it's happened once. The lane assist without ACC seems to be a tad jittery as described by baltfan. With ACC on, it seems to be more stable.
I was recently on the notorious Capital Beltway with AAC and lane departure on. Was cruising along nicely and then saw a sea of red lights ahead. The ACC decelerated smoothly and came to a complete stop - waaay cool. It was able to maintain composure with stop and go traffic until there was a break and the car in front sped up quickly. This seemed to confuse the ACC as the Q7 did not start back up. I turned the ACC off and sped up to prevent the folks behind me from leaning on their horns! The manual suggests that I could have pulled the ACC lever forward - resume - to get the car moving. So much to learn. |
Originally Posted by jmike52
(Post 24793239)
I was recently on the notorious Capital Beltway with AAC and lane departure on. Was cruising along nicely and then saw a sea of red lights ahead. The ACC decelerated smoothly and came to a complete stop - waaay cool. So much to learn. |
