LED headlights are a bit low
Old 12-31-2016, 10:35 PM
  #11
bhatiaax's Avatar
How many turns did you do? I'm worried left and right going to be off. Also, does this throw any code changes to the car??? Thanks!
Old 01-01-2017, 05:03 AM
  #12
1stq7's Avatar
I lost track of them. I kept foing back and forth to adjusting them to a point that I felt they are bright and far enough but not blide other cars. And the car did not throw any error codes.
Old 01-01-2017, 05:24 AM
  #13
bhatiaax's Avatar
Thanks. Are you happy with the results? I will make the change today.
I am still confused as to why they are not corrected by the factory??
Happy New Audi Year!
Old 01-01-2017, 05:51 AM
  #14
1stq7's Avatar
They are much better after setting them higher. I feel more confident driving it on highway at night.
Old 01-01-2017, 05:56 AM
  #15
Eppieguy's Avatar
I turned the adjusters 1 full turn on both sides, much improved, no codes.
Old 01-01-2017, 12:30 PM
  #16
dbull's Avatar
Assuming you turned them clock wise, right?
Thanks.
Old 01-01-2017, 04:54 PM
  #17
Eppieguy's Avatar
Thanks.
I forgot, what I do remember is that I had them on up against my garage wall and I saw I was turning the wrong way so I went back to where they were aligned and turned 1 full turn the other way. Basically you can't screw this up as long as you're watching them on a wall at a distance of about 15-20'.
Old 01-02-2017, 06:27 AM
  #18
PROEDGEBIKER.COM's Avatar
+1, i also used my garage.
Has anyone noticed that the driver's side light is lower than right? even when you even them out, the passenger is always higher.
Old 01-02-2017, 06:38 AM
  #19
BigKutta's Avatar
I believe this is by design in most cars, so as not to blind the oncoming driver. In most cars I have owned, the drivers lights dips a bit lower
Old 01-02-2017, 06:41 AM
  #20
VipinLJ's Avatar
+1. That's how it is in all cars. So as not to blind the driver in the car coming from the opposite direction.
