LED headlights are a bit low
#32
RickObe:
Unfortunately for me I listened to the earlier posts and went clockwise. I had simply made 1.5 full revolutions with my tool in the clockwise direction with the car off while in my garage. Figured I would see how it looked on the road the next evening then adjust from there.
After your answer, I decided to go back and reverse what I did. Then something told me to pop-off the plastic trim panels covering the adjustment area.
And low-n-behold........Audi placed a marker right there with a "V" indicating vertical adjustment with arrows for UP and DOWN.
You were right. Counterclockwise!
Thank you.
Thank you.
#34
RickObe:
Thank you.
Thank you.
#36
RickObe:
Thank you.
Thank you.
#37
It should be okay to do the adjustment with the headlights switched on, right?
And will any screwdriver work? Like say. A Phillips screw driver? Or do we need a particular one?
#38
RickObe:
Thank you.
Thank you.
Just putting it out there...
#39
It would be best to do the adjustment with the headlights on so you can see the movement in height. I used a flat head screwdriver, it was real easy to turn.
#40
Nice, but the question now is that is it counter clockwise for both sides? Did you pop off the other side as well? For example, if the passenger side (which I assumed is pictured) is counter-clockwise, it wouldn't surprise me that the driver side is a mirror image and the direction is clockwise.
