LED headlights are a bit low
Old 02-25-2019, 09:22 AM
  #51
V13T's Avatar
Originally Posted by mhoran89
No, if you adjust on level ground to your desired height then the car (when neutrally loaded on flat ground) will return to that setting you changed it to.
The car does the sweep every start up to level the beam height. But it goes back to whatever you set it to at that ride height (ie. how much stuff in trunk etc.) if that makes sense.
If you put 1000 lbs in the trunk and restarted car, it would end up on the same place on the wall. If you emptied trunk and restarted it would do the same. The car looks for how loaded it is every time you start. But you set the height manually through the adjustment screw that the car then adjusts off of....
ahhhhh thank you!
Old 02-25-2019, 01:02 PM
  #52
mhoran89's Avatar
Received 1,159 Likes on 907 Posts
Originally Posted by V13T
ahhhhh thank you!
No problem!
