Low Beam step-up
Low Beam step-up
Don't know how best to say it best but in my 2011 Q7 TDI, the low beam used to step up so you could see further when you would hit speeds around 60mph. When doing faster than 60mph and you had to slow down to under 60, you would see the low beam drop down a little. In my 2018 Q7 with LED lights, I don't see this happening. Maybe there is some coding that can do this? Since these headlights tilt up and down at startup, I'm thinking this is possible. One thing I also miss about 2011 was when the headlights would move side-to-side when you were making a turning (above certain speeds).
I doubt it. Since the Q7 was supposed to be equipped with matrix LED, it renders the low-beam adjustments during high/low speeds pointless. The problem is that we, in USA, aren't equipped with matrix LED headlights.
specialblend
03-24-2005 08:28 AM
audi80greece
02-07-2005 12:15 PM
