Minimum oil alert came on
So other day I had been driving around running errands and the an alert came on say that my oil level was at minimum but I can still drive and to add a quart of oil.
My q7 is 2018 and when the alert came on it had about 6500 miles on it.
Anyone else experience some like this?
i ended up adding a quart of oil and the light went off, I’ve had about 12 cars(mostly lease) so far in my life and have never seen this on a new car.
Quite common. Your car used about a quart (litre) over 6500 mi which is on the higher side but also not surprising because cars can use more oil during break-in. Also, you don't really know for sure if the oil level was at maximum from day one. Nothing to be concerned about.
Just a PSA for everyone on here...
When my car was in for service recently and the recall fix, I checked the app right before picking up the vehicle. It showed that the oil level was a bit above 1/2 between min and max. It was almost down to min before I had dropped it off, so I knew they hadn't added enough oil with the change. I called my SA before leaving, and he had it topped off for me to full. Probably bought me a month or two of not having to top off...
Check your oil level after an oil change....
I also noticed my 2018 with about 4500 miles has Oil level is 2-3 bar less than full on the Audi app
what oil should I use? CASTROL EDGE 5W-30 C3? When should I add?
please advice
thanks
please advice
thanks
Being down a 2-3 bars is normal, nothing to do yet. when it's close to being down to a minimum, it means you are a quart low. At that point you add a quart of the Castrol Edge
