Minor annoyances and "did they really?"
#101
Heck there’s been several situations where I’ve wanted to move the car with the doors open: Backing up ramps to perform inspection/maintenance/learning activities, pass a 24” pipe wrench on a back road and back up to ****** it off the ground, leave the door open on an all wheel drive dyno to perform tunes, moving the car 10’ to make room for the backhoe I wouldn’t normally close the door or even pull my left leg into the car. Letting the dog out to herd cattle id normally push the brake, let her jump out, push the gas and close the door while in motion. Lots of low speed door open driving in my back woods and country experiences. Just sucks the park brake getting slammed on me all the time. I’ll check out the link up there and adjust my habits I suppose.
#103
I wish there was a setting to eliminate that function. I can understand having it is a safety feature by default, but I'd like to have the opportunity to permanently disengage it. Heck, I have VCDS so I could do it via coding, if only the option exists and I knew how..... it's gotta be in there somewhere?!?
#105
#106
After the parking brake engages automatically due to an open door, if you shut off the parking brake, it will remain off and allow you to drive with the door open.
#107
Correct. While I havent stopped to pick up a wrench in my Q7 yet, this is how the feature is disengaged in BMW.
#108
Appreciate all the info and the comments. Ha, I would probably consider myself as part of the .1% club! I’d imagine there is a way to code the setting out, not sure I’d do it with the multiple folks that drive the Q...
#109
I knew I wasn't imagining, this is not the first time it has happened.
#110
Ultimate Keyboard Warrior
I have a few long lights I sit at when coming home from work. When in my S5 I sometimes set e-brake and take my foot off brake pedal until light changes.
Tried this in my new Q7, and the motor started and stayed running. So it appears setting the e-brake turns off auto stop.
