Sponsored By:
Sponsored By:
Night Vision
Old 02-17-2017, 05:41 AM
BigKutta's Avatar
Default Night Vision
I'm really pondering adding this to my order, but not sure how useful it will be. We live in the burbs, with plenty of deer, fox etc on dark winding two-lane streets. There is some night driving, but short drives to and from people's homes or dropping/picking kids. I've had a few close calls with deer, but no hits yet, but see dead deer all the time. I think I would be ideal candidate for this feature, but am not sure if its very effective and/or is a distraction while driving. If its was $500 I wouldn't think about it and turn it off if I dont like it, but for $2500 I am overthinking this.
Please provide your inputs and though process behind getting/not getting this option. Thanks!
BigKutta is offline
Old 02-17-2017, 08:01 AM
If I live in the areas with lots of wildlifes, I would get it. There are some but we're talking once-a-year encounter.
With Night Vision you also get headlight washers, which I regret not having.
Keyser Wi is offline
Old 02-17-2017, 08:44 AM
I had it in an A7; it was a cute gimmick at first but over the period of time I owned the car, I used it maybe a dozen times, half of them to show people how it worked. I find a years subscription to XM/Sirius more useful and less expensive.
zekeman is offline
Old 02-17-2017, 08:46 AM
BigKutta's Avatar
This is what I'm afraid of too, plus my wife will drive it mostly and will likely not use the feature much.
BigKutta is offline
Old 02-17-2017, 05:17 PM
Dasaint's Avatar
Out here in Washington people are always darting across the streets and sometimes highways. They also walk in the street I'm certain parts. I put mines on every night if I'm driving. Latest catch was a guy standing really close to the road talking to a truck driver stopped in the incoming lane. Was going downhill so was pitch black ahead but the NV light him up. I almost removed it but I'm glad i didnt. Many highlights and 1 avoid warning so far.
Dasaint is offline
Old 02-17-2017, 09:48 PM
plat27265's Avatar
It only takes one hit, one accident to regret not having Night Vision.
plat27265 is offline
Old 02-18-2017, 04:00 AM
JDS680's Avatar
Have to admit it was hard making a habit of turning on the NV when driving at night, but now that it's a habit I appreciate the added safety that comes with it, even while I'm using other features and it's running in the background. I live in a mostly rural area where deer are plenty- NV sees the deer earlier than I can - It'll pick 'em out on the roadside, outside of headlight range. Years ago my wife and kids hit a deer in our mini van- luckily no one was hurt, but the damage was well over $2500. Night Vision was worth it for us.
JDS680 is offline
Old 02-18-2017, 12:46 PM
I had night vision in my S7. As mentioned before, I also viewed it as a gimmick. I thought exactly the same thing regarding deer, etc. Counting on it to prevent hitting them is folly at best. Most people that hit deer due them darting out in front of them from no where. I also felt it was a distraction that I finally shut off to quit looking at it. Just me experience after 2 years in the S7. Also, if you ever bang the front end, it is REALLY expensive to fix. The night vision camera(s) are very sensitive to position. I had a small dent in the front valence and they quoted me big dollars to repair due to the night vision setup. I passed on the repair. You asked for input and that was my experience. I can't remember, but read the fine print. I seem to remember that the alarms would not sense animals...only people. You may see them but no alarms. Just something to check.
mikemdd is offline
Old 02-18-2017, 12:59 PM
Here are a few exerpts regarding the system:
""The marking, the gong, and image contrast can be configured via the MMI. Like every assistance system, the night vision assistant also works within certain system limitations. Highlighting of detected pedestrians is switched off at air temperatures above 28 degrees Celsius (82 degrees Fahrenheit), for example.
The image processing software can detect persons at a range of approximately 100 meters (328.08 ft). When analyzing the data, it specifically seeks out human contours and objects that are bright and round their heads, in other words. Detected persons are highlighted with a yellow marking on the display. If the control unit predicts a hazard because a person is walking on the road close to the car, for example, the person is marked in red and a warning gong sounds.
It has an angle of view of 24 degrees, and its protective window is cleaned by a separate nozzle and heated when cold."
Key points:
With a 24 degree view, it limits what is on the side of the road close to you. Also note the alarm limitations. Anyway, just a few more data points in your decision.
mikemdd is offline
Old 02-18-2017, 06:34 PM
I love the night vision. It has alerted me a few times to people on the road that i will not have seen. I just hate its narrow field of vision. Usually I need to see what is on the side of the road but the NV only sees straight ahead. So its only useful for looking into the distance. We have a lot of squirrels where i live. Being able to see the sides would make the system perfect.
Gani is offline
Quick Reply: Night Vision
