Night Vision
Old 05-29-2018, 10:33 AM
  #11
BlackOptics's Avatar
Assumed parts list so far:
Camera
Controller (where is this to be located?)
Harness
Grill (maybe the existing one could be modded or adapted - if not grille replacement seems easy)
Bracket
Dash Switch
Washer for FLIR camera. (probably activated by the NV controller - assuming it has a data input for when the headlight washers are triggered)
I am looking for a source where to obtain the drawing and schematics for the NV components?
Old 05-29-2018, 11:12 AM
  #12
Dasaint's Avatar
Comes in handy for me as people always darting across the road in the dark where I live. See them way ahead of headlights. A quick glance work. Just like checking anything else on the dash. It alerted me to someone in the way early morning one time and I somwhow didn't see them. The best use I got out of it was seeing a cop hiding up the street.
Old 05-29-2018, 12:17 PM
  #13
Part Numbers found so far.
Camera 4G0980552A
Camera Bracket 4M0980561
Harness
Grill GRILLE EMBLEM BRACKET. INNER COVER. 4M0853169C
Dash Switch Headlamp Switch 4M0941531AD5PR
Washer for FLIR camera. Headlight washer hose (w/ night vision) 4M0955970D
Old 05-30-2018, 06:07 AM
  #14
Can someone assist with these part numbers?
Controller 4M0907547B <- need this verified. Where does this mount?
Harness ???
Old 05-30-2018, 07:59 AM
  #15
rafi.kadafi's Avatar
Please check if your instrument cluster PN supports night vision !!!
For after market components you will need to have a service visit to void component protection which is tight to VIN number
Old 05-30-2018, 08:02 AM
  #16
Old 05-30-2018, 08:14 AM
  #17
Thank you, very help help. I should have mentioned my region is USA. What is the source of the diagrams? I am able to obtain access? Parts diagram for the headlights washers would be helpful. Right just doing scope analysis for cost of parts. I also need information on programming. I am assuming that installing and connecting everything won't make it function without programming.
Old 05-30-2018, 08:23 AM
  #18
Its VAG Etka (catalog of all parts)
Full version you will find here
https://ifinterface.com/page/page3.php?langid=1 than click on left CarProg2
Set up your veihicle data and region (I believe EU/US in this case it the same)
For programming you will need VCDS or Vag-COM pro or ODIS. I do not know on new platfrom how to perform.
I beleive also that calibration is needed
All procudures and diagrams you will find in program called ELSA Win. You need to google it
Old 05-30-2018, 10:57 AM
  #19
Vehicle has virtual cockpit.
What does " void component protection" mean - programming? By "After Market" do you mean original parts installed after delivery? In USA "After Market" typically mean non-original parts.
Old 05-30-2018, 11:16 AM
  #20
In 4G platform there was diffrence between instruments clusters supporting or not Night vision.
For parts I meant "used" in other vehicles not new from Audi dealership.
Such componets as night vision you need to program @ Audi to your VIN number
Quick Reply: Night Vision
