OBDEleven
#631
Thanks Rick, really appreciate it. Where is a good place to purchase the item from? Can a non-Pro device be upgraded to Pro later on?
#632
https://www.shopdap.com/vw-audi-scan...obdeleven.html
Yes, you could buy the device and the Pro software upgrade separately direct from Voltas in Europe:
https://obdeleven.com/en/
Not sure why you'd want to do that since it would end up costing more and the device without the Pro software isn't all that useful.
#633
Got the unit today and turned off start/stop right away, I found 3 places where you can turn start/stop off so I did all of them. 2 are from the A/C module.
However, when I tried to enable automatic PDC front under Central Eletronic's long coding, I do not see bytes/bits (I also have VCDS so I am familiar with that, but it doesn't work with my Q7). It gives me a bunch of parameters which I don't see anything about PDC. Anyone else have the same issue?
#634
Enable Automatic PDC Front
[09 - Central Elect.] [Coding - 07]
Select Long Coding Helper
Select Byte 37
Check Bit 1
The front sensors are now triggered when you approach an obstacle. Only the graphic with sensor "bars" flashing pop up on the main MMI screen - does not activate the cameras.
There might be an issue with this depending on your build date. Mine was somewhat early (March 2016). If I'm not mistaken, laters builds had this enabled from the factory (my 2017 A4 & 2018 Q5 did)
#635
Is it possible to do an ANC calibration using OBD11? I know it can be done with the VCDS (looking at calibrating the active noise cancellation after making exhaust changes).
Thanks
Thanks
#636
It's a little obscure how to change from textual coding to bit/byte coding. You have to tap the little 0 1 icon at the top of the screen:
#637
This is what I did on my 2017 (Prestige) with OBD Eleven:
Select Byte 37
Check Bit 1
Select Byte 37
Check Bit 1
#638
2 from a/c module and 1 from central electronics.
#639
I tried the A/C one which worked to disable A.S.S. Undid it, and did it in central electronics and seems to work the same as far as I can tell.
