OBDEleven
#761
Has anyone tried to dim the the default brightness of the virtual cockpit? I find the gauges too bright at night. I saw coding posted for Q5 but not sure if it would be the same...
#762
There is small **** next to headlight mode switch which you press to protrude, and rotate right and left to adjust brightness of all screens and illuminations within the cabin. Never heard of software adjustment of VC and other screens
#763
https://www.audiworld.com/forums/q5-...ckpit-2940117/
#765
Hello, does anyone have the security access code for A5 adaptation? I’ve tried 20103 and it isn’t working. I am currently locked out for 30 minutes. Trying to finish up the adaptation for Active Lane Assist. TIA
#766
Security codes
09 - Central Electrics: 20113
13 - Auto Distance Regulation: 20103
6D - Trunk Electric: 12345
#767
So, I used both codes and it doesn’t work. I put in 20103 and hit search after a few minutes I cancelled it and it logged me in? Anyways it works now. Thanks
#769
No AC module OBDEleven for Q8???
Dylan, That's not the right coding to disable start/stop. At least not the coding that others have been successful with. Here's the coding you need:
Module: 08/Air Conditioning
Adaptation => A/C comfort param for start/stop function
Old value: 5
New value: 0
This tricks the system into never activating the start/stop as long as the HVAC system is not turned all the way off. If you do turn the HVAC all the way off, you will sometimes get a momentary engine stop and immediate restart. But who ever turns the HVAC all the way off these days?
Old value: 5
New value: 0
#770
