Q7 4M Hidden Gems List
#201
The system works great. But you must watch the road.
Heres a a hidden gem. If there’s two cars in front of you as you’re coming to a stop and the first car in front of you changes lanes... the Q won’t see the other car that is still stopping and will attempt to drive right through it!
#202
Sometimes the DA stuff helps and others can hurt (literally)...we have turned off Pre-Sense as making left hand turns in an intersection can set off violet panic braking as the vehicle in the opposite lane passes by while one is turning. Apparently if the turn signal is not used it's not an issue...turn signals however are meant to signal ones intentions and should always be used especially when other vehicles are present. Hoping the system has been tweaked for the Q8's and the rest going forward, but from what I hear about lane tracking issues still persisting, I'm hopeful but skeptical.
#203
Yes, I agree. It will slow down for curves in the road. However, in order for it to slow down for a turn at an intersection (one where you have the option of not turning), then it you have to be navigating for it to know that you are expected to turn.
#204
Yeah that was I was saying in the original post.
#205
Ultimate Keyboard Warrior
#206
In higher density areas such as NYC, when trying to make a left turn and trying to fit in between onslaught of oncoming vehicles, the turn assist would get triggered almost every time as it either sees an incoming car or it stills "sees" the car that it's just in the process of passing you. The key here is that you need to be fully stopped prior to attempting your left turn, if you are moving it will not triggering the turn assist.
#208
My 2017 US Q7 does that with adaptive cruise control on *and* with ‘Adaptation to route ahead’ checked in the MMI (and, obviously, only if navigating with a set destination). If that option is not checked, it won’t slow down, say, at an intersection where a turn is scheduled according to the nav.
#209
#210
Lot of misinformation in this thread. netrom17 is right - you have to enable this feature with the adaptation feature checked on in the MMI... Simply having adaptive cruise control and navigation working does not automatically make you slow down at curves/intersections unless this option bit is checked.
