Q7 Choosing between running boards, AWS and Tow Assist
Old 06-21-2017, 08:26 AM
MartinCheshire's Avatar
Default Q7 Choosing between running boards, AWS and Tow Assist
In process of buying Q7 but for some reason I'm unable to select as options all three of the above. I can only choose two of Running boards, All Wheel steering and Tow assist. I don't understand why?
Also if I were to get AWS and running boards, could I then, after delivery, fit a detachable tow bar?
Help and advice would be appreciated
Old 06-21-2017, 09:36 AM
Greystoke's Avatar
Due to GVWR restrictions Audi doesn't like to put the Tow Package and Running Boards on at the factory or port. You can install the running boards later or the tow package later. The tow package has the greatest differential between port install cost and dealer install cost so I would choose that one to order.
After you purchase you should receive a coupon from Audi for a discount on accessories. You can use this coupon to purchase your running boards.
Grey
Old 06-21-2017, 09:38 AM
Greystoke's Avatar
Note that I am assuming you are located in the US.
Grey
Thank you. Will probably look into that option then
Old 06-21-2017, 09:39 AM
Grey
Actually in UK but guessing the answer will be the same
Old 06-21-2017, 12:27 PM
srbsq7's Avatar
There's been a lot of discussion about running boards and all wheel steering on the vwaudiforum. I don't think there's been a conclusive answer but you can't have all wheel steering with the running boards - maybe with 3rd party alternatives but not Audi OEM.
Here's the thread: http://www.vwaudiforum.co.uk/forum/s...running+boards
Old 06-21-2017, 06:04 PM
AUDI1880's Avatar
I may be wrong, but seem to recall reading somewhere the reason you can't get running boards and AWS is due to clearance issues.
Old 06-21-2017, 06:08 PM
gsobol's Avatar
You can get it with boards and AWS. For some reason boards and towing are not compatible. Beats me why.
Old 06-21-2017, 10:43 PM
Gani's Avatar
you cant get boards and AWS
Old 06-22-2017, 12:37 AM
Atvars's Avatar
You can get (at least here in Europe) running boards in combination with AWS, but then trailer assistant isn't available. Running boards can not be combined with trailer assistant, I don't know why...
Quick Reply: Q7 Choosing between running boards, AWS and Tow Assist
