Q7 Seat Ventilation
I started to use the seat ventilation and set it at max level, but hardly notice the seat getting that cold. I can feel that the back of the seat is a little cool, but nothing like some of the rentals I have had in the past. Does anyone else have any input with regards to their seat ventilation? Just need to know if I should take it in and have them look at it?
Mine like this too. I can feel it but its not blowing me away. I tested it in a friends MB and it was the same...
it works decently well when you have the lowest 'LO' temperature on your A/C. mine works quite well and I believe the coolness is dependent on the A/C temp.
Originally Posted by Nomarian
(Post 25034491)
They work by pulling the hot air away from you rather than blowing cold air at you. That's why they are referred to as ventilated and not cooled.
Mine definitely seem better some days than others, I think it is corollary to how hard the AC is working. Also if you're wearing thicker clothes its not as noticeable (presumably unlikely during the summer when you'd want to use it)
Originally Posted by alipor
(Post 25034535)
Mine were like this, I did adjust the fan speed via Vag-com this helped the most. The AC seats in my raptor would freeze me out, but those were AC not ventilated. I think that is the difference.
(Post 25034491)
Mine is subtle. I have never tried other ventilated seats. I expected more cool air flow. But I am ok with it.
They make too much noise though at anything but the low setting, so I don't feel like I can leave them on high. So they are not an AC duct? |
Originally Posted by rsilvers129
(Post 25034878)
So they are not an AC duct? As mentioned earlier, if you are feeling it on your back but not your seat (or vice versa), check the setting in the MMI A/C section to make sure it's not set for back or seat only. |
